Question about Schaerer Opal Espresso Machine
Opal telling me beans lid is not on when it is ?
Hi - I have an Opal, very good but just recently mine is telling me that the beans lid is open when its not therefore not grinding ! - very annoying. Id love some assistance !!
  • DaveHarmer Jan 20, 2008
    Hi, thanks for your suggestion. I may order another lid however I cant seem to see any physical damage to the existing one. I have posted some photos on my website so you can have a closer look. If you can let me know how you can jam it that may help also.
    Thanks again for your reply, it seems impossible to find Schaerer techs.
    Sorry, the website is
  • 29 Answers
Easiest way around this problem is to wrap electrical tape around the plastic piece at the rear of lid which inserts into machine to close the switch. Sometimes these switches used to shift slightly and the piece on the lid would not make the connection properly. So as opposed to stripping the machine down to reposition the switch which is quite tricky and time consuming, it was a lot easier to wrap tape around the insert on the lid so it would make contact once inserted.
Posted on Mar 24, 2014
i work on schaerer machines. on the back of the lid there are two plastic spikes that make contact with in the machine, when you lift the lid it breaks contact so when you select your product you dont put your hand near the grinder. order a new lid or write back and ill tell you how to jam it open. If you want?
Posted on Jan 19, 2008
I need a description for how to open and clean the grinder. I keep getting fill beans message and it has beans.
I have not done it, but I believe you simply remove the two screws you can seen when you look into the coffee bin.
I used to get "fill beans" messages when there were beans in the hopper. Eventually I determined this was due to my choice of beans: oily (ie. shiny) beans seem to clog up frequently, "dry" beans (beams without a sheen) rarely clog up.
Since the beans are gravity fed, oily ones tend to stick to one another
May 01, 2015 | Jura Capresso Impressa S9 Coffee...
How do i change grinder setting while its running
I don't believe you can. There is a switch that turns off the grinder if you remove the lid to the bean hopper. The grinder adjustment is under that, unless you bypass the switch in the lid (which can be done) you cannot get access to the grinder adjustment.
Jun 26, 2014 | Saeco Odea Giro Plus Coffee Maker
My mp3 player opal m4204 - a doesn't work anymore!!! stuck on the initializing screem which says ''low battery'' ''shutting down'' what can I do?? my computer didnt recognie it either HELP!!!
Mines doing the same thing i can suggest trying it on another computer. If that works then you need to install the lastest update of firmware on your mp3. Tell me if that works for you.
Oct 26, 2009 | RCA OPAL M4001 MP3 Player
I bought new green coffee beans recently, roasted it myself and wanted to use it in the machine but the grinder gets stuck and won't turn. The new beans are harder and smaller than the type I used to have....
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Oct 21, 2009 | Gaggia Paros Espresso Machine
I suffered with a stuck grider unti for a long time and just solved the problem..... Remove the filter basket and through the front door look up twords the back left. You can see where the grinder unit sits. There is a slot area where you can stick a screw driver under the grinder unit and pry it up. Do this in a jiggling motion and make sure you are well under the grinding unit, doing so on the edge of the grinder unit underneath will not give you enough suface to work with, in fact you will just bend or crack the edge. Looking in from low on the front (kneeling on floor with unit on counter, worked for me) will let you locate where the screw driver or smal pry tool needs to go. Mine was stuck for a very long time and No amount of pulling or prying from the top would work, I made it pop out in a matter of seconds using this technique from the bottom! Good luck, I'm going to finish my cup of coffee now! :-) Steve
a little cooking oil on the shaft before you insert the grinder will help, spray on pam works well and is easy to do...
Jul 01, 2009 | Cuisinart Thermal DGB-600 Grinder
How do i use the pressure cooker? After adding water and beans, I let it come to boil and the steam noise is steady....then I turn down the heat? At the end I let out the steam manually, turn off and open...
Add the water and beans. Put the lid on the cooker and tighten down. Turn on the heat and let the steam make a full plume before closing the valve. Lower the temperature to medium. Watch the gauge and when it reaches the correct pressure keep adjusting the heat to maintain the pressure for however many minutes the beans need to cook. When the time is up turn off the heat and let the cooker cool for a while. Ten minutes or so. Then slowly open the pressure valve when the pressure has reduced to a low level. If the pressure is still to high when you open the valve the water will be pulled out of the beans and the jars will only be half full of liquid. Once the pressure is down to zero, open the lid carefully because the jars are still hot and break easily. As the jars cool you will hear them pop. This means that they are sealed. Good luck.
Jun 15, 2009 | Kitchen Appliances - Others
The top of the unit that covers the coffee beans has a plastic point that must depress a button on the main body of the unit when it closes to show the unit that the lid is closed properly. If this is broken (as was mine) I inserted the end of a piece of tooth pick replacing the plastic point in the lid and this now depresses the recessed button on the main unit. The beeper goes off and the on light comes on.
Jun 19, 2008 | Cuisinart Thermal DGB-600 Grinder
How to format an RCA OPAL m4002RDA
Reformating will take all your songs off I think.
If your trying to put songs on
Plug your mp3 player in, open my computer, open RCA and drag songs to the correct folder.
If that didn't help or you need more help, please respond.
Good luck.
Feb 26, 2008 | Audio Players & Recorders
Schaerer Opal Espresso Machine Logo
199 people viewed this question
Top Schaerer Coffee Makers & Espresso Machines Experts
Are you a Schaerer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
