Brother Fax 560 will not stop running the cartridge. The cartridge can be replaced, the door closed and it will not stop running until the cartridge is empty. How can I fix this problem?
Unfortunately there is no fix for this problem as the system board is corrupted. Try powering the machine of from the wall socket and then powering back on. If this doesn't work the machine will be more cost effective to replace.
One question though is it an original cartridge that is installed if not install a new original ink cartridge.
Cheers J
Rating Locked! (?) wonderboy2 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Brother Fax 560:
Solution #2
posted on Feb 23, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
when sending a fax, how can I set up the fax machine to have a confirmation of the fax sent.
godfrey
Was this solution helpful? Show your Appreciation by rating it:
