Question about Remington Polesaw Wizard
Shuts off worked well for a while, but after using it for awhile motor will run fine until you put saw against wood, and then it shuts itself off. You can restart it, but again once you put it against the wood to cut, it shuts back off.
  • Anonymous Jun 03, 2008
    The saw will run until you put it against the wood to cut, then it stops.
  • 211 Answers
Hi Icestorm
check the piston rings,the seals .the cilinder and the gaskets.Clean the air filter
yours savumihai71
Posted on Dec 02, 2008
How do you change a blade on model 36-075
Lots of saws have left hand threads on the nut that holds the blade in place. It is designed so that if the saw starts up and the nut isn't snug, the nut and the blade slipping on the turning arbor would tend to tighten the nut as they slip against the force of the spinning arbor.
1. Unplug the saw.
2. Hold on to the blade tightly with one hand.
3. Put the wrench on the arbor nut and turn it in the direction you would turn it as if the wrench were turning the blade to cut wood.
If you've previously overtightened the blade, jamb a piece of wood against the teeth and the saw table top and then follow step 3.
If the motor is on the left side of the blade as you face the saw, then it's a standard right hand nut.
If the motor is on the right side of the blade as you face the saw, then its a left handed nut.
Sep 17, 2014 | Delta Circular Saw Blade, 10 Dia, 50T -...
How do you change the blade on a craftsman 10 inch radial arm saw
put a block of wood against blade to hold it then loosen the nut that holds the blade to the motor .
Sep 02, 2014 | Craftsman Radial Arm Saw W/ Stand 10 In....
New to table saw use, have my husbands old 10 craftsman, was learning to rip with it doing fine, then it started to bog down during cut until the blades stops, moving. put on a new blade and noticed...
If I understood correctly, you started using your husband's table saw and while ripping boards, you managed to stall out the blade AND motor?! If that's the case, you probably have a very dull blade and are binding your board on the blade. Neither is safe and it sounds like trouble is brewing.
First and foremost, get someone to show you how to safely and properly use and adjust the saw if you are new to wood working and power tools. That saw is capable of turning your lumber into a high speed missal if you do things improperly.
It also sounds like you tried installing a new 10" saw blade. Changing the blade requires 2 wrenches. One to hold the arbor and one to tighten the nut. The blade itself should rest on the arbor between two large washers. Also make sure you install the blade so the front face of the cutter teeth face you and rotate toward you. Make sure the saw is unplugged when changing the blade and never turn on your saw with a loose blade.
Oct 20, 2013 | Craftsman 10" Table Saw
Blade stops when feeding wood
It may be that the motor is under powered for the load, but more likely it sounds like the motor is defective. Perhaps some of the windings have shorted. That might allow the blade to spin, but stop under any load. What brand and model is this saw?
Jan 30, 2018 | Bosch 4000 - 07 Electric Table Saws
I just received a "LICOTA"
The extra brushes would likely be for the motor, and not used until the saw has LOTS of miles on it.
The allen usually backs off a clamp that holds the blade. In terms of metal and wood, the blade itself determines that. HOWEVER, Consider using and possibly distroying a WOOD blade. If there is metal in the wall, you usually do NOT want to cut that...!! I suggest cutting the drywall side first and see that there is nothing in the wall that you do not want to cut!!
The metal blade can cut wood, no worries.
Feb 13, 2011 | Saws
I have an older model 12 in table saw every once and awhile motor will start t smoke after using only a couple mn.
The motor or the wood piece your try to cut? because if the motor is "smoking" i bet it do it once.So change the saw blade and post back please.
Oct 12, 2010 | Craftsman 10" Table Saw
How to cut a 45 degree angle on wood using a jig saw
use a combination sliding square to mark ecxactly where you want to cut. Measure the distance from the jig-saw blade to the edge of the jig-saw bottom plate. Use this distance to mark another line parralel to the first line. Nail or screew a straight piece of wood on the second line. Put the jig-saw plate against the wood fence and cut your perfect line.
Mar 17, 2010 | Franke EuroPro Series GN1845SP Solid Wood...
Nothing inn the canister after using,suctione working,bottom roller working,no air leaks from hoses.Also when running awhile it shuts off by itself,have to wait awhile to use again
I'm not sure what vacuum you have, but that sounds like a blockage to me. Thermal shut off kicks in, shutting the motor down, to prevent damage from overheating. After waiting like 1 hour it probably comes back on. Make sure hose, filters, bag (if any) is clean. All "airways" of vacuums need to be clear of any blockages, since airflow is what makes vacuums work.
Apr 18, 2009 | Vacuums
Remington Polesaw Wizard Logo
46 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
