Question about Sony FD Trinitron WEGA KV-32HS500 32" TV
Picture got darker then usual everything else works fine and bulb is ok
2004 sony wega big screen
  • 4,402 Answers
Replace blub?
Posted on Jan 28, 2008
Sony wega 3LCD . the old bulb was replaced because the set was darker. the new one shuts the tv off. with a blinking red light for 3 times between pauses.
Before u change the lamp for this tv,tv set work fine wright?Yes.Just have dark and dim pictures only wright?Yes.Recheck the tv installation of the lamp again,recheck the door safety latch and colse properly and tightly.Should solved this problems.
Jul 30, 2011 | Sony KDF-E55A20 55 in. LCD Television
I noticed that my TV Sony Wega LCD Projection TV picture is darker than before. I tried to set brightness to very high, but still seems to be darker
hello, if you go in to the menu and click on to picture setting half way down the screen is the word reset click on this it should make it brighter hope it works
Dec 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Picture to big for the screen
You need to adjust your aspect ratio, you need to consult your manual
link for user manual above.
Apr 01, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a sony kf-60we610 2004 and the bulb is good, but the tv doesn't stay as bright as it use to and I have the brightness max out. any ideas?
IF the lamp has been in the set for a while it may be your problem---some of these sets before the lamp fails the picture will get darker--lamp will look ok but can cause this trouble.
If you replaced it at some time with a "Generic" replacement other than an Original Sony--that can also be the trouble.
Lamp life is about 2,000 hours and time can pass quickly.
Let me know if I can help--I am here to help.
if this information helped you rate this solution as I do this here for free.
6bc0523.jpgSony XL2100U lamp.
Dec 26, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
My sony wega 60 lcd projection flat screens picture is getting darker and the lamp light will flash every now and then
That is a typical lamp failure, dimming of the picture, eventually the bulb may go out from time to time causing the picture to come and go, it is time for a new bulb. The bulb is located under the front panel, there are two thumbscrews on either side of the set in the back, loosen these screws and pull off the front panel, the panel has some snaps, so it will not come off easy, tug on it and you will hear several pops indicated the plastic retainer has let loose, then you will see a door near the center of the tv with another thumbscrew, you bulb is under this. Flap.
Sep 24, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Wega KDF-50WE655 has purple spots, support says wega engine bad
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described sounds like one of the circuit boards that control the picture quality needs to be replaced. The cost of the board would likely be in excess of $200. There are usually several boards in a TV like that that control the picture and when one goes, you can get anything from lines in the picture to poor picture quality from blurriness. The main question is do you want to spend $1000 to fix a used TV?
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 04, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-60XBR950
Problem of darker picture in your TV shows expiry of Lamp (bulb) at rear of TV.
Aug 15, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony WEGA KDF-55WF655
What you need is the owners manual my friend. In here it will show you where to get to the lamp and how to change the lamp. Go to
to get a free copy of the OWNERS manual. Page 16 tells you how to do this. Good Luck
Jan 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Green Screen?
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Nov 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony FD Trinitron WEGA KV-32HS500 32" TV Logo
41 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
