It is not normal if there is less traffic - in and out of the fridge or freezer - if all is ok.
At night it should run less. You have 1 condenser fan to service both freezer and fridge compressors, which run independent of each other though they both regulate the condenser fun.
If you you have a dirt condenser coil (on to of the appliance), the cooling effect reduces, causing the compressors run longer till the meet the cabinet set temperature. Every time a compressor runs, the condenser fun runs.
If you have less traffic and have a clean coil, then call a service tech.
I hooked up the waterline to the icemaker for my Subzero 661 icemaker but after two days still no...
(More)
I hooked up the waterline to the icemaker for my Subzero 661 icemaker but after two days still no ice. There is adequate water pressure and it's cold enough in there to make ice but either there's a blockage or some starter switch I can't see... or something else? Help!!!
bottom half of the freezer section is not getting cold or freezing, also the ice machine is not...
(More)
bottom half of the freezer section is not getting cold or freezing, also the ice machine is not making ice; refrigerator was professionally serviced 1 month ago; they replaced the automatic defrost timer and cleaned the coils
how long until new sub zero 48'' begins to make ice? Also, any reason why freezer drwaers condensed...
(More)
how long until new sub zero 48'' begins to make ice? Also, any reason why freezer drwaers condensed & frozen if new machine?
