Question about Zenith D60WLCD 60" Rear Projection HDTV-Ready Television
Zenith Projection TV blurred
Corners on Zenith Projection TV out of focus
  • Anonymous May 03, 2008
    zenith model num. pvr4663rk 46in.
  • Anonymous Jun 01, 2008
    my tv is older and has red and green wavey lines going through it,I tried to adjust it but it is just not clear.thanks Debbie
Out of focus
Posted on May 03, 2008
My zenith big screen tv is out of focus and we cant find any master focus control. How do we fix the focus?
It is unusual for a rear projection to be out of focus since the projectors are fixed. But, it is common for the projectors to be out of alignment, in which case the picture will look like a bad 3D movie of yesteryear.
Go to the setup options / menu, look for the ALIGN option, follow instructions on screen.
Jun 13, 2010 | Zenith R60V26 60" Rear Projection...
Blurred picture and it's also dark rear projection zenith Z52Z95D
I'd get the lamp replaced for sure. If it has a ballast - change that at the same time. However, a Zenith repair center should be able to tell you whether it's worth doing or not.
Jan 05, 2009 | Zenith Z52Z95D TV
My big screen in slightly out of focus and will blur now and then. there is also a cracking sound when the tv is turned on
Do you have a setting in the MENU where you can adjust the "Sharpness". If you have this setting, go up a few notches toward the "+" side and see if that helps. Also, there might also be a section in the MENU called "CONVERGENCE" and in this menu, select the "AUTOCONVERGENCE" option and it will reset the screen. You may or may not have this option in your menu, but if not, you should have something where you can adjust the focus. My TV is an RCA projection and I have the setting that I mentioned above, so your should be somewhat similar. As far as the cracking sound goes, some TV sets will do this with age when they are first turned on and are going through the whole "warm-up" process and that should not be a big concern. Hope this helps...
Sep 08, 2008 | Zenith Televison & Video
Zenith Blurry Picture
i got a zenith tv and the picture is really blurry how do i focus it ?
Feb 02, 2008 | Zenith R57W46 57" Rear Projection...
Zenith rear projection tv 56"
The convergence is way off. You may be able to adjust it thru a service mode menu. You'd need to get the model number first.
How old is the set?
Thanks,
SF in Vermont
Jan 29, 2008 | Zenith IQB50M90W 50" Rear Projection...
Blurred Corners
hi there, its a decousing problem, look for the connection of the decousing which is connected behined the pic tube to the board. check some electronic parts, it may be temperature resistor, termistor, transistors, capacitor, etc.ty
Dec 25, 2007 | LG Studioworks 775N 17" CRT Monitor
Zenith D60WLCD 60 in. Rear Projection
CALL ZENITH AND PROVIDE SERIAL NUMBER AND PROOF OF PURCHASE. THEY WILL SEND TECH OUT TO FIX OR REPLACE TV. THIS IS A PROBLEM WITH MANY PROJECTION TV'S BECAUSE OF A FAULTY PART.
Oct 03, 2007 | Zenith D60WLCD 60" Rear Projection...
Zenith blue corners
Sep 02, 2007 | Zenith D60WLCD 60" Rear Projection...
Blur
Most likely a unit this age with start showing signs of weak crts. These crt's hava a life of 7 to 10 years and your discription is failing crts. I am afraid it is time to move to a new unit.
Dec 25, 2006 | Zenith D60WLCD 60" Rear Projection...
Zenith D60WLCD 60" Rear Projection HDTV-Ready Television Logo
177 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
