Question about Memorex MMP3642 MP3 Player
Need help cant download musicmatch
0 characters
1 Points
I have Musicmatch Jukebox 10 but have just changed over to Windows 7.I have a Packard Bell Hard Drive.How do I update from xp please ?
Musicmatch Jukebox 10 is not compatible with windows 7 >>
MusicMatch Jukebox 10 was designed to be used on older 32-bit operating systems like Windows XP.Note that MusicMatch Jukebox 10 is also no longer being developed, so it is unlikely that these problems will be resolved in future.
Before proceeding with installation of Musicmatch Jukebox 10, you need to look on your Windows 7 PC for any previous versions of Musicmatch Jukebox. If you've already tried installing version 8, for example, then you need to run a complete uninstall, not to mention a good clean up of the registry.Use Revo uninstaller to uninstall and clean any registry trash ,revo uninstaller can be downloaded on the link below:
Once you have done this, or if you had no earlier versions of Musicmatch Jukebox installed, you will need to download and install the only suitable version.Download and Install Musicmatch Jukebox 10 on Windows 7 >>
Once downloaded, right-click the installer file and select Run as Administrator. Next, you will need to OK the first of many warnings that the file is incompatible with this version of Windows.Proceed through the installer, clicking Next at each option.When you come to the registration page, click the option to not register and also claim to be under 13. Click Next to complete more steps of the installation, changing the location required for your Music folder if necessary. Musicmatch Jukebox 10 will add files and playlists to this location.As the installer finishes, you will be prompted to install the Yahoo! toolbar. You will need to deselect this.A successful installation should result in more incompatibility warnings. Ignore these, but agree to reboot your PC. Next right click Musicmatch Jukebox icon and select properties > compatibility >check run this program in compatibility mode for: (Windows XP) click apply ->ok.
Nov 13, 2011 | MP3 & Digital Media Players
Musicmatch Jukebox shows just PSS instead of PSS110.
This is the LEAST of your problems - the official MusicMatch service was cancelled in October 2007, so you are only going to get limited functionality out of this player in the first palce. If the jukebox is working, don't mess with it. If it is not working:
Download the newest version of the Philips Device Manager: - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
-Tha Mp3 Doctor
Jan 24, 2009 | Philips PSS110/17 MP3 Player
Cant download music to my player
yes just hook it up to usb and use it like an external hard drive ... I know for sure it works if you saved them in usb mode havent tried the mtp mode but figure it should be the same ...
after you find your files have musicmatch up and just double click the explored files on your mp3 and as long as you got it hooked to the comp. they will play in your playlist... or ya can just drag and drop them into the playlist
Jan 14, 2009 | GPX MW-238B MP3 Player
Rca kazoo rd1000b
There is a driver for it that will work with XP, however, the issue is finding a program to make use of that driver. The brain surgeons at RCA decided to not include a program to put music on your MP3 player and instead relied on third party software... that software being MusicMatch Jukebox. Of course, somewhere along the line MusicMatch dropped support and even if one were to acquire an old version of the program, you have to download a MusicMatch plugin that allows it to recognize the MP3 player... a plugin that no longer exists on the MM website. Isn't that wonderful? Currently, I'm looking into the matter, and if I find a solution, it will be posted.
Apr 25, 2008 | RCA RD1000 Kazoo MP3 Player
Hi there
Make sure you are using Windows XP and Windows Media Player 10.
Also make sure you have installed Musicmatch Jukebox from the product CD.
The PSS110 is not compatible with Vista or Media Player 11.
If you have Media Player 11, then uninstall to roll back to version 10.
Also, you need to make sure the player is showing as "GoGear" and not "Removable Drive".
If Musicmatch shows the player as "Removable Drive", go into the options menu and click devices. Click the dropdown menu showing "removable drive", and select "GoGear"
Mar 09, 2008 | Philips PSS110/17 MP3 Player
Old RCA Lyra RD1080 - How to Convert files .mpy to play on iPod
Simply put you cant you can convert to mpy using musicmatch jukebox to your player but thats all sorry
Nov 18, 2007 | RCA Lyra RD1080 MP3 Player
How the heck do i download my cd's to this darn MP3 player ???????????????
I hope you have Windows XP. Download Musicmatch Jukebox (google it). Open up Musicmatch Jukebox and on the left hand side is a link to download songs to the MP3 player. Click on the link and follow the directions. Musicmatch Jukebox does not work on Windows Vista (yet).
Nov 05, 2007 | RCA RD1076 MP3 Player
RCA lyra RD 1080
make sure the the music is in mpy format which musicmatch converts it to when loading it on your device also if its in wma formate i think it needs to be 128kbps or higher also try to use your player to transfer the music to the mp3 player dont drop and drag
Oct 15, 2007 | RCA Lyra RD1080 MP3 Player
Seeing files in musicmatch jukebox
Musicmatch is now cancelled - Oct 2007
Jan 23, 2007 | SanDisk Sansa e260 MP3 Player
Memorex MMP3642 MP3 Player Logo
18 people viewed this question
Top Memorex MP3 & Digital Media Players Experts
Starnley Johnwells
Starnley Johnwells
Are you a Memorex MP3 and Digital Media Player Expert? Answer questions, earn points and help others
