Question about Frigidaire ATF6000ES Front Load Washer
Washes fine will not spin
I can get into the diagnostic and the spin works fine, wont spin during regular wash cycle.
    Sergeant:
  • 264 Answers
Your brushes are gone you will have to wright down your model number and look on ebay there really cheap
Posted on Jan 07, 2008
What causes my LG fuzzy logic fully automatic washing machine model WF-T1050TP does not do washing cycle but can spin during spin cycle
it appears the motor's sensors could be going bad on it so the diagnostic computer doesnt know what to do but spin the motor in a spin cycle contact LG for a replacement motor for this washer
Sep 11, 2016 | LG Washing Machines
Noisy and wont agitate during wash cycle. will spin and drain.
the strap (belt) is chipped, damaged, the spindle from the VAT ruptured, cracked the tank squealing stops, etc. more details please
Feb 16, 2015 | KitchenAid Washing Machines
Hi i have a SIMPSON ESPRIT 600 TOP LOADER WASHING MACHINE. The wash cycle works fine however during the drain and spin cycle, the water wont drain. The machine makes a noise during the drain cycle but...
My guess would be replace the pump, it is normally driven by the motor and if the wash cycle is good the motor is operational. You have to investigate to find the actual part to replace.
Dec 03, 2014 | Washing Machines
My machine wont run, i replaced the drain pump and thermostat sensor.
Depending on your model pushing soil level and spin speed at the same time then hitting the power button will start it in diagnostic mode from here out pushing start will check its features, door lock, low spin, high spin, pre wash, wash, bleach, softener, rinse, drain, spin...ext
Jun 01, 2014 | LG WM2688HWM TROMM SteamWasher
Wfc7500vw spins but not at high speed on final spin
This is a common problem with the Whirlpool front load machine. The motor control board goes out but the new ones have been redesigned. You will need to replace the control board. Here is a link to the control board you need.
Oct 17, 2012 | Whirlpool WFC7500VW Washer
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
My LG TROM wash googd but dosn't want to spin
Check and see what type detergent you are using. I bought regular liquid detergent and the machine began making noise during the spin cycle and the drum would not spin. I was informed that you have to use detergent that is labeled HE (High Efficiency). The regular liquid detergent will suds up during the wash cycle which then causes the drum to slip and not spin during the spin cycle. What you are hearing during the spin cycle is the drum slipping. Unplug your washer for 30 minutes and let it reset. This lets the suds dry out. Run a cycle with no spin to rinse out the drum. This should eliminate your problem. If you have clothes in the machine, run a cycle with no spin, just don’t add any more detergent. Then run the normal cycle with spin a second time with no detergent. I hope this cures your problem.
Apr 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine clothes dry
Is the belt broke? Have you checked during the wash cycle if it is agitating.
Mar 28, 2009 | Washing Machines
Wash machine will not spin
sounds like a problem with the coupling between to motor and the gearbox!
Jul 15, 2007 | Kenmore 24032\24036 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
59 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
