Question about Logitech 250 Headset
Only one speaker on hte headset is working
I plugged it in, tried to play some music, i only hear from the right side of the headset, not the left, is this fixable or is that damage beyond my repair?
  • 3 more comments
  • Anonymous Jan 08, 2008
    This happens with practically every headset I have ever bought. I've always wanted to know the answer!!!
  • Anonymous Feb 03, 2008
    same problem, but do not know the solution.
  • slashcry Feb 07, 2008
    please, if anyone has any idea how to fix this, please inform us. its getting slightly irritating with sound in only one ear
  • pamyo Apr 22, 2008
    I too have this problem - with several headsets, as we use them in our office.
    I don't think it's a wire problem.
    We're on Mac OSX. They work perfectly fine other than nothing in the left ear.
    I can't find ANY solutions on the web. Is there anyone out there who knows what that problem is?
  • Anonymous Apr 04, 2009
    It cant be a cable issue because I use these HD headsets and my right ear wont work on my PC. However I can prove its not a cable issue because I hooked it up to my MP3 Player and both ears were working. Any solutions to this??
This is a cable problem and it must be re-soldered. But i cant find a way to open the headset without breaking it! Any tips?
Posted on Apr 15, 2008
Even I have encountered the same problem with Logitech headset.Also my microphone is not working at all.
I thing I noticed that when I tilt the cable connected at the end of microphone towards the other direction both the speakers work as I hold the cable in that position.But when I release the cable only one of them works.
Posted on Mar 20, 2008
6ya staff
SOURCE:
SET A RINGTONE & PLAY MUSIC
u need to change the phone sound ic or change the phone speaker.
Feb 13, 2012 | Samsung B3310 Cell Phone
Tip
How to connect an iPod to a Tritton AX720 Touch
<p>While the Tritton AX720 headset is designed to communicate with other users play games on Xbox 360 and PlayStation 3 game consoles, can also be used to play music from your iPod to surround improving the sound. The kit comes with AX720 Controller in a row to adjust the volume of the headset to adjust, and in combination with an audio cable to connect the controller online for the iPod Touch. Unfortunately, since the iPod Touch is connected to the controller in-line, you cannot communicate with other users if you play a game simultaneously. <br /> <p><br /> <p>1. Connect one end of the stereo audio cable to the door on the right side of the controller online. <br /> <p><br /> <p>2. Connect the other end of the audio cable stereo headphone port at the bottom of the iPod Touch. <br /> <p><br /> <p>3. Connect the headset cable into the headset jack is located on the back of Tritton AX720 amplifier. <br /> <p><br /> <p>4. Connect the power cord from the power amplifier of the port, and plug the adapter into an outlet. Press the power amplifier, which is found on the front of the unit. <br /> <p><br /> <p>5. Press the "Play" button on the iPod Touch to play the music to start. Slide the wheel on the right side of the in-line volume controller to adapt the music to hear. <br />
on Aug 05, 2011 | Computers & Internet
NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't hear...
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Hopefully that should fix the issue.
Jan 01, 2018 | Nokia N73 Music Edition Smartphone
Had about 4 pairs of the same brand of headset and after about 7 or 8 months lose hearing of sound form the left side. Always the left. their is no sign of tear in cable from out side and it cost a lot of...
The Left Side speaker unit(driver) of the headphone is different from right side. left side has more connections and soldering points, main cable goes to left side and chances of oxidization is more, because of cable movement(if cable goes to both sides of the headset, than it damages the side where cable movement is high). try to carefully open the headset and check the connectivity with multi-meter, If it is cable problem then trim the cable and re-solder. Or as you told you have 4 pairs, and you have broken ones. swipe the speaker unit (drivers). Besides both left and right drivers have different connections, it is possible with little soldering knowledge. hope you got it. thank you
Sep 02, 2017 | Labtec Radio Communications
I can only hear out of on side of my turtle beach headset
Connect the headset to your PC and listen to some music (green plug & USB). If the sound plays out of both ears, then the headset is fine.
Why don't you contact Turtle Beach directly for help?
Jul 10, 2010 | Voyetra Turtle Beach Ear Force X1 Headset
The left side wont play music but the right side will play it completely
hi there, I had skull candy earbuds in the past. The problem is that the left side has a short in the speaker. It means that you need to get a new pair of earbuds as they are not fixable.
Mar 02, 2010 | Skull Candy Smokin' Buds Headphones
ITouch 2nd g only plays music throuhg left side of all headphones
Try playing with the headphone plug, until you can also hear the right
channel and also try a different set of headphones as it is probably a
matter of an intermittent headphone jack, or plug, owing to sudden
snatching of the headphone plug from same, a very common problem.
Eliminate this cause before submitting your Touch for much more
expensive remedies
Apr 16, 2009 | Apple iPod touch
Sound Problem
try pressing on the volumen button a little hard maybe its damaged.
Nov 02, 2008 | Logitech 250 Headset
Palm treo
THE phone's Headset Plug is stucked. Try to plug and Un-plug the headset many times for it will release. Best, Play a Music and try this on so when you haer the sound coming from the phone, it means it works
Jul 29, 2008 | Palm Treo 680 Smartphone
Music not playing through bluetooth
take it back and have the csr from the store correct the issue but first try a new one and see if it works.
Feb 01, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Logitech 250 Headset Logo
772 people viewed this question
Top Logitech Radio Communications Experts
Ekse
Marvin
Marvin
Thomas F. Schneider
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
