Question about RCA Scenium D40W20 40" Rear Projection HDTV
52"RCA Rear Proj. TVs turn off and on then not at all
I have two of these tv's and in two days both have gone down. The first one stopped all together yesterday and the other one stopped working today.
The last one will turn on for about 2-3 seconds then shut off by itsself and then turn on by itsself and do this a couple of times and then it will not work ata ll for about 5 minutes. Then I turn it on and the same thing happens again.
Please help?
  • Ozzy69 Jan 12, 2008
    Had a tech come and look at them and found out some boards needed sodering. Must have been caused by moving the second TV after the first one stopped working. They are both fixed for about $100 each.
Did u have a lightning storm or a power surge. sounds like too much of a coincedince for both to go down with out a spike in the electrical supply.
Posted on Jan 12, 2008
52 RCA REAR PROJ. TV WONT TURN ON.
The problem will be the deflection board (left hand side board when looking from back of unit.Part number is 258762 is no longer avaible thru rca but you can contact tristate module or pts electronics-you can even google the part number
Sep 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA REAR PROJ. SCREEN BOWS AT TOP AND COLORS DOUBLED
Hi, thank you for visit fix ya.
Resolder all connections around fly back ( check for open pico fuse).
if still problem, replace convergence board.
Thank you
Jul 27, 2009 | RCA HD52W58 52" TV
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20v 52 in proj tv
The capacitor you are looking for is on the Deflection Board on bottom is 2 boards on left is Deflection board on right side is SSB board it has the turners on it.cp150,cp114,cp120 these are the 3 capacitors to replace if cp150 is puffed up on top.
Jan 04, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA 60" projection tv Turns on and starts flipping channels by it self
replace the keyboard or remove the switches for channel up/down to see which one is bad. if neither does it, there are some components around the microprocessor that can cause this.
Jul 27, 2007 | RCA P60921 60" Rear Projection Television
RCA 52" will power on but shuts down immediatley
plz get the picture tube ic's basically when green light mostly appears on the tv it is said that there is a roblem in tv ic's
Feb 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
RCA Scenium D40W20 40" Rear Projection HDTV Logo
69 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
