Question about Fahrenheat FBE15002 Baseboard Heater
Electric baseboard heater
Just bought today a Fahrenheat electric baseboard F25408 heater and there are no instructions in the box. I need to know how to install - I am replacing an old heater. I also purchased a Fahrenheat double pole thermostat (built-in line voltage) so I need to connect this also. I have a red and a black wire available and need to know how the thermostat and the home wiring attach.
  • Anonymous Mar 23, 2014
    need to know how to wire the heater with its own thermostat to the electrical wire in the walls
    Sergeant:
  • 288 Answers
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Posted on Jan 09, 2008
I am puchasing a 28 YO home with electric baseboard heating. Will this be satisfactory or have there been much advancement made in baseboard heating used today?
To put it simply; any other heat source is better than your existing baseboard heaters. Yes, there have been sincere advances. Here is an informational website:
http://www.heater-home.com/FAQ_baseboard.aspx
Hope this helps some:)
Farmerbear
Aug 30, 2010 | Fahrenheat Electric Convector Baseboard...
IS A HYDRONIC ELECTRIC BASEBOARD MORE EFFICENT THEN THE STANDARD ELECTRIC BASEBOARD HEATER
I have some confusion about what you are asking......
There is no such thing as "Hydronic Electric Baseboards"......
I am assuming you are referring to the oil filled baseboard heaters. If so....
The same amount of btu's required to heat a space remain the same whether the elements heat a liquid to warm the air or whether they heat the air directly, the same amount of wattage will be consumed. So, their is no more or less efficiency between the two.
If you are referring to "Hydronic Baseboard Heaters" (these baseboards are fed from a boiler with a pump) Then....I will assume that it is a gas boiler. In which case, the gas boiler would be more cost efficient to operate. If it is an electric the same rule applies as above......the cost is the same.
Oct 04, 2009 | Fahrenheat FBE15002 Baseboard Heater
Fahrenheat electric baseboard heaters are not safe for children
A few companies sell child-proof covers that prevent little fingers and small objects from getting into the radiators. Try searching Child-safe baseboard heater covers in a google search or PexSupply.com.... we use them in daycare centers.
Jan 29, 2009 | Fahrenheat FBE15002 Baseboard Heater
I need a wiring diagram for a Fahrenheat electric baseboard heater. model # F2546NWC 1500 watt.
i dont have a diagram but i just did mine,,,its real easy to do...write back if you didnt solve your answer yet...
Dec 26, 2008 | Fahrenheat Electric Convector Baseboard...
BASEBOARD HEATER NOISE
HOW ABOUT THE MARTIN HEATERS I LIKE THEM BUT DONT USE THEM THAT HIGH
Dec 04, 2008 | Fahrenheat Electric Convector Baseboard...
Please i need help with 240v wiring to heater
i have the answer, i just did mine...though u already have your answer since this post was published a while back ago...if not write me back...
Sep 12, 2008 | Fahrenheat Electric Convector Baseboard...
How do I wire up my fahrenheat F25408 baseboar heater?
Baseboard heaters are easy to hitch up. You can have a wall mounted thermostat or an integral thermostat. The diagram I have is for the integral thermostat. Follow the diagram and it should work.
Nov 28, 2007 | Fahrenheat Electric Convector Baseboard...
Fahrenheat FBE15002 Baseboard Heater Logo
533 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
