if you dryer is working ok and you can feel that it is heating you may have a blocked air intake or outlet check these out if ok your thermostat may be faulty hope this helps
I have a gas dryer that has a bad thermostst how can it be replaced Do 110 dryers use more...
(More)
I have a gas dryer that has a bad thermostst how can it be replaced Do 110 dryers use more electricity than the 220, are they safe
I have a kenmore dryer model #110.63942101. The drum will not continue spinning once I release the...
(More)
I have a kenmore dryer model #110.63942101. The drum will not continue spinning once I release the button. (It spins as long as I hold the button) The timer and heat seem to work and the buzzer goes off after the appropriate amount of time. I am hoping that this is something that I can fix myself. Any ideas?
