Question about Kenmore 15121 Built-in Dishwasher
18 in dishwasher drains water during cycles
My dishwasher drains water during cycles.Shortly after filling I hear water going out and the dishwasher keeps running through cycle. What can I do? I had repairmen come 2 or 3 times and they never fixed the problem.Please Help.
  • 90 Answers
Find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Posted on Jan 05, 2008
I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
Oct 13, 2011 | Dishwashers
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Apr 18, 2011 | Kenmore 1348 Builtin Dishwasher
My dishwasher detergent dispenser still has the detergent in it when the dishwasher is complete with the cycles. I hear it fill and go through the process but dishes are dirty and soap isn't gone
Sounds like it is not getting enough water ( up to element) The water has to be 130 F to work well. Is the water draining out after fill . Just open during cycle and check these things
Nov 22, 2010 | Kenmore Dishwashers
We discovered broken glass dish in bottom of dishwasher with some pieces below the bottom pump area. Shortly after the washer is making a louder noise during operation time. The water pump is quite when...
sounds like you have broken glass in the wash pump you will have to remove pump from sump and clear also check the drain pump.good luck let me know how it goes
Jun 22, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Not filling with enough water only filling partway
The fill cycle is a set time and not measured. Either your water pressure is low at the dishwasher or the screen on the fill valve is partially blocked keeping the correct amount of water from entering during the fill cycle.
Eric
Jan 11, 2010 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool built in dishwasher. not aware of model number
Putting vinegar in the bottom of the dishwasher is not going to help because it has nothing to do with the FILL cycle. The bottom (or sump) actually is used during the WASH and DRAIN cycles. I would check the fill port where the water inlet hose goes into the side of the wash tub. You will need to pull the unit out and locate the inlet hose on the SIDE of the dishwasher. The hose should be a black rubber hose located on the left-hand side of the machine. I had a very similar problem that turned out to be calcium deposits clogging the fill port BEFORE it got to the fill valve. With the unit turned off, I removed the rubber hose and used a small screwdriver to poke straight down into the fill port and break up a bunch of calcium. The unit worked fine after that. It is normal for some dishwasher models to drain if they do not detect enough fill water, or if they detect a leak. Usually when the fill port becomes restricted or clogged you will find puddles of water forming under the dishwasher. You might want to remove the bottom panel and check for leaks as well (if you haven't done so already). If you check the fill port and it is clear, the fill valve could be a possibility as well. However, you mentioned you could hear water running which leads me to believe that you have a simple clog somewhere...but, the valve could have accumulated some deposits as well. Check the fill hose and let me know. Good luck and I hope this helps you. PS Another common mistake people make is to put drain cleaner in their dishwashers. This can damage the pump and chopper assembly. Not to mention, it could be harsh on the some of the rubber seals. Not a good idea.
Jul 30, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Kenmore 15121 Built-in Dishwasher Logo
382 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
