Question about Dishwashers
Kenmore dishwasher 665.15625690
Kenmore dishwasher is about 10 yrs old. It stopped working except when you put the dial in the pots/pans range about 2/3 of the way toward the normal wash cycle point. It will run for about 1 - 1 1/2 mins and then stop and there is about 2 inches of water in the bottom. I have tested the timer and it shows in the high end of the normal range at about 2800 ohms... what should I check next?
4 Suggested Answers
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
  • 297 Answers
SOURCE: Kenmore dishwasher model 665 stalls in mid cycle
you have a clog somewhere.
Posted on Jul 15, 2009
  • 55 Answers
SOURCE: My Kenmore 665 has the
This means the touch pad has failed, You would need to replace the touch pad to fix this issue.
You can purchase the touch pad from the link below.
Appliance & Refrigerator Repair
Posted on Mar 23, 2011
Testimonial: "It started to work again, but if it happens again, I'll know what to do! Thanks for the help!"
The pots and pans light and normal light is blinking
Kenmore Elite Dishwasher blinking light Control Board FIX ...
? 1:37
www.youtube.com/watch?v=flzhfmIIYpM
Apr 14, 2011 - Uploaded by MegaHowtoMan Kenmore Elite Dishwasher blinking light Control Board FIX ....year old washer, did a google search for the problem, and your video came up.
Sep 01, 2015 | Dishwashers
I have a kenmore Ultra wash dishwasher Model # 665-16022400 apprx 7 yrs old-everything was working fine till xmas of 2011-then when you pushed smart wash then try to press start nothing happens-also you...
Well, Larry, it sounds as if you've tried just about everything.... except replacing the control console (with keypad), and if everything else is okay, then that is PROBABLY your problem.
Jan 09, 2012 | Kenmore Dishwashers
Kenmore2007 665-575-320 won't start,clean indicator stays on
Kenmore 665-1374 Dishwasher, suddenly front touch pad not working, at first would allow pot & pans, now no settings, with exceptions of drying settings
Jun 28, 2010 | Kenmore Dishwashers
Pots and pans and normal wash blinking
Try resetting it. Locate the switch in your breaker box, and flip it off- then on again. Hope that works!
Aug 09, 2009 | Kenmore 13743 Staimless Steel Built-in...
The Pots Pans button flashes and won't let me change it
Go to your circuit breaker panel and turn off the circuit that feeds you dishwasher. Leave it off for three minutes. This will reset the program and should solve your problem.
Apr 04, 2009 | Kenmore 15634 Built-in Dishwasher
Dishwasher won't cycle through to rinse/dry/stop
Your timer switch is most likely defective.
It probably needs to be replaced.
It is like a clock with switches at different times
If it is stuck at a particular time it will run there forever.
Before servicing disconnect power!!!!!!!!!!
You can remove inside door panel with about 6 phillips screws or so.
Timer is directly attached to the dial on your machine.
These cost about $100.00 or less.
Can also be found used online for cheaper.
Oct 26, 2008 | Kenmore 24 in. 17512 Built-in Dishwasher
Quick Rinsw button blinking
I may have fixed my similar problem- I opened up the machine to get access to the control panel as tech17 advised- then in addition to disconnecting the mylar ribbon, I disconnected all the connections to the control panel.... keep in mind to ensure not to confuse any of the connectors you disconnect. Running a cycle at this time... seems as if working.. can't tell if water is running or just the motor- -- HA! -- i confirmed no water being pumped in.... We then found a float switch (Item 30 on schematic) that got loose from its casing on the front interior right lower side... we put that switch into its proper place and now ALL IS WELL!!!! Yippee!!!
Feb 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher's "Pot-n-Pans" light flashing
ga, behind the toe panel on the bottom there should be a tech sheet explaining how to put the dishwasher in the test mode. See if you can enter the test mode. If you can't, you probably have a stuck or shorted keypad. Catriver...post back
Mar 03, 2007 | Kenmore 24 in. 16009 Built-in Dishwasher
Dishwashers Logo
88 people viewed this question
Top Dishwashers Experts
