Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
How to get songs
I have tried to put songs on my sansa by drag and drop from limewire and its not working, i doont know how to get to mtp mode and putting songs on my sansa is getting very complicated for me.please help.
---mikey
  • 3 more comments
  • mpersaud
    mpersaud Jan 08, 2008
    NED SOME HELP!
  • mpersaud
    mpersaud Jan 12, 2008
    the sansa is not recognizable on my desktop but it is on my laptop, how come?also i tried drag and dropping mp3 files from limewire to the sansa media converter and its not working.
  • mpersaud
    mpersaud Jan 16, 2008
    thanks
  • lillovely1 Feb 28, 2008
    my computer is not recognizing the device wat do i do
  • Anonymous May 15, 2008
    i can't get songs from limewire to the mp3 but i can't please help!
    Problem Solver:
  • 6 Answers
When i used LIMEWIRE i remember being able to go to the folder on my comp with all of the songs that i downloaded. i think i went to FILE then "Open containing Folder" or maybe "Explore Folder" then i moved all the songs i downloaded into my regular MUSIC folder under MY DOCUMENTS.
That way i could access all the songs when i wanted without opening LimeWire.
Just figure out how to view the folder where all of your LimeWire files are, then you should be able to move the files directly to your player or other music folder for easy access.
~Rebecca~
Posted on Jan 16, 2008
  • 4 Answers
You have to sync it, I know i had the same problem!
When you conect it, you should have a screen saying what action to take go to sync.
You have to put your songs in there then sync
Posted on Jan 11, 2008
Can't locate the music on the player in windows explorer. Every folder seems to be empty. The player itself recognize and plays about 230 titles...but where are these files located on the player and why...
The location of all the music on your Sansa is Clip+/Internal Memory/Music.
If the folder is empty, you should now think on which mode you you transfer the songs MTP or MSC. If you transfer songs on MTP, you can only see them on that mode and vice versa.
Try to check the current settings on your Sansa by going to MENU/SETTINGS/SYSTEM SETTINGS/USB MODE
Try changing the USB modes and check the folder again.
If songs are not showing on both modes, possible that the files are hidden or corrupted.
Mar 02, 2011 | SanDisk Sansa Clip MP3 Player
MTP or MSC mode
If you use a micro SD card, put it in MSC mode, if not, keep it on the default MTP mode.
Apr 29, 2009 | SanDisk Sansa e270 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Cant load songs
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
My sansa e200
-Plug in your mp3 player
-Go into 'Limewire', select a song and go 'Locate file/Open Containg Folder', you should be in your folder with all your songs. or go 'My Music' and find your music files.
-Either select all your songs, open them with 'Windows Media Player' and transfer them that way.
-Or 'Open My Computer' then open 'Sansa e200' and drag the songs from where your songs are located [My Music] to the 'Music' folder in your Sansa e200 folder.
[MyMusic] Song.mp3 >drag to> [MyComputer/Sansa] Music.
Dec 26, 2007 | SanDisk Sansa e200 MP3 Player
Help
You may have to put this device in recovery mode and apply a force format file to it.  If you have put songs on from Limewire or any other infamous bad source, that is prob the culprit. The sandisk website has the file you can add to the player.  Recovery mode is simply:
1. put on the hold button
2. while holding the record button in, plug into computer at the same time and keep holding the record button in until you see recovery mode on the player
after you do this, you can drop the format file on the player by going to my computer and locating the 16MB icon, then drag and drop the file on the player.
Once you have done this, unplug the player and take off the hold button, and it will reboot itself and format itself to the neutral state from the factory setting.
Oct 21, 2007 | SanDisk Sansa e250 MP3 Player
Formated the SanDisk Sansa E280
You dragged & dropped files in recovery mode? Recovery mode is only for re-installing the firmware or formatting the device if it is unresponsive. If you are wanting to drag and drop files onto the device, the music needs to be put into the Music folder on the device. If you do not see the Music folder, you will need to enable hidden files and folders on your PC. Best of Luck. p.s. - you can add to this question this doesnt work.
Oct 08, 2007 | SanDisk Sansa E280 MP3 Player
Can't delete songs from the e200
I had this same problem with my Sansa e280, I did some research and found that MTP mode is used when syncing with Windows Media Player.  So if you plugged in your player under MTP and simply tried to drag and drop using Windows Explorer the player won't recognize.  I have heard that you should be able to view them on the Sync tab in WMP but I personally have not tried.
The way I got rid of the songs was by going into my Sansa Settings and changing the USB mode to MSC, opening the Player by going to My Computer, then (if using Windows XP) click on Tools > Folder Options.  Click on the View tab and Select "Show Hidden Files and Folders".  Click "OK" Then Right click on the MUSIC Folder and Select "Properties"  Uncheck "Read Only" and "Hidden".  Unplug your Player and it will restart.  Viola, no more ghosted songs.
Apr 30, 2007 | SanDisk Sansa e200 MP3 Player
Can i use limewire?
step 1; down load songs from lime wire. step 2; go to lime wires library, and about half way down the page there is a button called explore. click on it. step 3; open windows media player, and click sync. a list should show up, step 4; click on songs on shared folder, and drag to sync list. step 5; connect sandisk, and click synk to e 250 on upper right hand corner area, and wait for sandisk to write! hope this helped!
Dec 27, 2006 | SanDisk Sansa e250 MP3 Player
Problem with drag and drop
(FOUND THIS SOLOUTION ON AFTERDAWN.COM) The problem is that this player have 2 standards for connecting to PC. One is MSC and other is MTP. Each one have different directories structure. If you put music when your player is connected as MSC, when you will conect as MTP you'll be not able to see the files uploaded previous. The same case is available when you write music files as MTP=> you can't see these files in MSC mode. So, set USB mode of your Sansa as MCS, power off, put hold switch to lock and connect to PC. You will see 3 directories: Audible, Records and Config (or something like that). See if your "invisible" music files are here. If they aren't connect as MTP. To connect as MTP: set USB mode to auto, shut down Sansa mp3 player, put hold switch to unlock and connect to PC. You will see only 2 directories now. Media and "something" (I can't remember now). Look for your "invisible" files and do what you want. MTP mode is for use with newer PC's. I advice you to use MCS mode all the time because is compatible with any PC (old or new). Good luck!
Aug 30, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
70 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
