Question about Sanyo DWM-3500 System
Remote for DWM-3500
Where can I buy a new remote? Machine works fine, just the buttons on remote are worn out (have to really press hard) on the remote from much use. Thanks!
  • dweiser717 Jan 18, 2008
    Remote Not working at all, Need to get a new one
  • MtnNurse Feb 11, 2009
    My remote control does not work...I need a new one.
What is model number on the remote for the 3500 dvd/vcr
Posted on Mar 13, 2008
The volume buttons don't work well at all. You have to push the buttons so hard to get it to work 20% of the time. I have new batteries. Other buttons work fine, just the volume buttons are the...
The first thing I would look at is the battery's some times they are not worn out but just need to be wiggled to clean the contact points. if that doesn't fix it you may need to switch to a universal remote. I Good luck.
Feb 22, 2011 | Yamaha RAV-250 Remote Control
Can only select channel 13 no other numbers respond. Channel selector only goes down, won't go up, volume control will only get lowers, will not always go down. Power switch does not respong. Have already...
Did you use your remote a lot?
Do some buttons work sometimes if you press them really hard?
If it's a double yes and you've already cleaned the remote (the rubber pad with buttons and the circuit board with contact tabs), then the buttons are most probably worn out, which means they no longer make a good contact on the circuit board tabs.
There's a repair liquid kit for remotes, i'm not sure what the brand name is or where to get it, in europe, conrad electronic was selling it some time ago, however, i make my own from benzene, rubber glue and grapphite powder.
The other solution is either to find a new rubber button pad or to get a brand new remote...
regards
3rq8 (Triarcuate)
Jul 23, 2009 | Televison & Video
The # 5 button needs to be pressed hard to respond All the rest are fine. It seems to have worn out.
you have solved your own problem! The # 5 button is worn out and that is quite common in all remotes. (not just the # 5 but any button or buttons)
Jul 22, 2009 | Logitech Harmony 550 Remote Control
Sanyo DWM-3500 5.1 Ch. Home Theater System
yes get a hold of them at -1-(507)263-7900
tell them make and what part you need thank you for useing fixya
Feb 11, 2009 | Sanyo DWM-3500 System
SANYO DWM-3000U combo dvd & vcr home theater system
I have a DWM 3000u that won't play some new DVDs. The movie is pixlated. Is there a firmware fix or do I need to buy a machine?
Lynda
Jan 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
NEED TO PRESS REALLY HARD TO INCREASE VOLUME. EVERYTHING ELSE WORKS FINE
as time goes buy more of the keys will fail to work, pressing hard on the keys may do some damage to the circuit board inside. you need to remove the batteries any and small screws you can see then pry the two haves apart remove any screws that hold the circuit board to the top half and remove the circuit board to expose the bottom of the key pad you will see a black conductor painted on the bottom of each key button, use a Q-tip dipped in alcohol to clean the black conductor on all the keys then do the same thing to the contact points on the circuit board then rub a pencil eraser over the same contact points on the cicuit board and reclean with alcohol again.
This should fix the problem but it will happen again, and at some point even this won't fix the problem and logitech won't let you buy a new key pad, and that is the point I am at now and for that reason I won't buy another remote from them, I expect more than four years out of this product good luck.
Nov 12, 2007 | Logitech Harmony 890 LCD Remote Control
Sanyo DWM-2500 Subwoofer bass output
You cannot access the bass settings with the remote. The remote that comes with the DWM-2500 is Sanyo Part #RB-TS760MT
Oct 28, 2007 | Audio Players & Recorders
I need a code for Citizen 3818 DVD Player
I have a good Philips Universal the code is 1908 Press Code Search until red light comes on Press VCR/DVD light flashes Press 1908 Light goes off It should work.
Jun 11, 2007 | Jensen JR400 Remote Control
Sanyo DWM-3500 System Logo
183 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
