Home | Maytag | Neptune MDE5500AY Electric Dryer | Change belt on dryer
Maytag Neptune MDE5500AY Electric Dryer
Problem for Maytag Neptune MDE5500AY Electric Dryer
By mgiannelli23 on Nov 07, 2009
change belt on dryer
Solution #1
posted on Nov 08, 2009
Not Rated)
hunter19_46m
Rank: Guru  Maytag Washers & Dryers  Expert
Rating: 92%, 159 votes
LWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune MDE5500AY
Questions and Unsolved Problems for Maytag Neptune MDE5500AY
Do you recommend Maytag Neptune MDE5500AY Electric Dryer?
Answer
Answer
quits working after one load will not restart for about an hour
Answer
the dryer reads power failure and you have to pust the start butter 50 times before the dryer will... (More)
Answer
Loud squealing noise and clothes not getting dry enough
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag Neptune MDE5500AY...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14768
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
