Toshiba 42H83 42 in. Rear Projection HDTV-Ready Television
Problem for Toshiba 42H83 42 in. Rear Projection HDTV-Ready Television
The screen is shaking horizontally. It does this
By kumar868 on Nov 07, 2009
The screen is shaking horizontally. It does this when I first turn it on and gradually gets better after about 30 minutes. There are also 2 or 3 vertical lines going side to side while the picture is shaking
Best Solution
posted on Nov 07, 2009
Very Helpful)
SD Tech
Rank: Guru  Toshiba Televisions & Videos  Expert
Rating: 97%, 1103 votes
42H83 is a Toshiba first made in 2003.
What is wrong (98% chance) is the HYPER BOARD in this set is now failing----all signal from all inputs is processed thru this board.
Considering the board is now only available on a rebuild basis----and the cost for this is well over 200 dollars not counting labor to remove--replace--set, unless you know someone who is VERY GOOD AT SOLDERING-----not worth repairing.
What happens here is this board has close to 20 surface mounted filter caps---with time and heat they dry out---usually the time before the problem clears up will get longer and longer---leaking caps may start to function to some degree after they get hot--hence the time from dead cold until the set works.
Most caps have 2 leads and are soldered through the circuit board----these are very small caps with tabs on them----and are soldered to the top of the board.
I am sorry to give you not so good news--but based on your description---I am sure it is your problem.
Call around your area telling them model number and you suspect it is a bad HYPER board---if a shop can actually fix it(replace the caps) parts cost would be under 30 dollars---
Any authorized Toshiba repair shop can go online and see the service bulletin for this--they have a large color picture of the board and indicate which caps have to be replaced.
If this information helped you, rate this solution as I do this here for free.
If you have questions or want advice let me know--I am here to help people.
SD TECH
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Toshiba 42H83 42 in. Rear
Questions and Unsolved Problems for Toshiba 42H83 42 in. Rear
Do you recommend Toshiba 42H83 42 in. Rear Projection HDTV-Ready Television?
Answer
Answer
the picture has a cloudiness or milky whiteness but brightness or contrast adjustment doesnt help
Answer
I have a 42 in toshiba tv chassis# tac 0395 when I turn on the tv it has a wavy screen that doesn't... (More)
Answer
I have model 42H83 TV. picture is fuzzy. Want to get att uverse but they need to know if this is a... (More)
Answer
hey my tv turn off automatically.. and only red light is blinking.. no picture nothing
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
