The CPU ( Central Processing Unit ) is the Pentium chip or Athlon Chip. To Plug your printer into your chassis, which surrounds the Motherboard is to first know the type of interface you have for your printer. If it is a 25 pin connector, you go into the 25 pin connector on the back. If it is a USB connector ( probably ), it plugs into the USB port on back. There are usually more than one of these. You may use any one and your computer should tell you " device found ". With questions like this, I'm not sure you're ready to fire up. Maybe you need a course.
skype calls break up after couple minutes. While I can still hear the person I am calling, he only...
(More)
skype calls break up after couple minutes. While I can still hear the person I am calling, he only hears very much noise and the call is breaking up.
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP...
(More)
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP scanning software, but I have not been able to install the scanner so that it works with the Vistascan software. I much prefer Vistascan as it is much more user friendly & offers more flexibility. Any help would be appreciated.
