Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Vista and the WWW
My vista enabled laptop will not let me access the BELKIN website to check for updates to my router. any ideas as my wifes XP laptop can access the site so it would appear not to be a web problem.
Hi I just had the same problem. I started with installing the provided software from Belkin into my Vista Laptop than
unplugged all wires than pluggin in the modem and powered it on than rewired the router and powered it on. The process wasnt done their though. The router needed configuration now I am not even close to somebody who knows how to do this heck i didnt even know it needed to be done so i phoned the help like 18002belkin *2263 and they where able to walk me through it we where doing things like turning on the automatic ip address and setting the dns address to 4.2.2.2 and 4.2.2.1 sorry i couldn't walk you through but best of luck to ya because I am now surfing from my living room. Happy New Year
Posted on Jan 06, 2008
6ya staff
SOURCE:
Belkin share N300 # F7D3302, wireless router is slowing down page loading on my wired tower computer. Running windows XP pro. Had d-link prior and it worked ok, just since replacing it with Belkin, this...
There may be a web filter or monitoring option enabled on the router... check your running configuration to see if you have any of these filters or monitors enabled
Jul 21, 2011 | Belkin N Wireless Router wireless router
Laptop can't connect to DSL-G604T
You need to configure your router and use WPA encryption so that all accessing device can connect to it.
The obvious reason why the dell laptop can't connect is because of the WPA encryption set. It is different compared with what your router is actually broadcasting: WPA2.
So you can choose one of the 2 things to alter. Change your router's WPA2 encryption to WPA or change your Dell's setup to WPA2.
Mar 05, 2010 | D-Link DSL-G604T Wireless Router
Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 29, 2009 | Belkin (F5D5231-4) Router
I DONT NEHW TO CONFIGURE MY ROUTER MODEM WIFI
First connect your router to computer with ethenret cable.
Then access folowing defaults l,ink
http://192.168.1.1
or
http://192.168.0.1
For belkin router
http://192.168.15.1
type user name as "admin" and password as "admin" or blank or "password"
then go to dhcp then enable dhcp.
Also check wireless is enabled.
If you want to secure your wi fi thne configure your router as WEP in WAN settings then add wep key it is your password to connect wi fi. Then save settings and restart the router. Let me know if you need more assistanse.
Thanks.
Aug 27, 2009 | Belkin (F5D7230-4) Router (587009)
How do i install my new belkin systyem when ive
yes you can use it.
first connect your Belkin router to computer with lan cable .
Then access it wityh this link.
http://192.168.15.1
user name as "admin" and password as "admin"or
blank or
"password"
then configure your router as your old lynksys settings.then save settings and restart .
Aug 22, 2009 | Belkin N1 Vision Router
My belkin router is secure how do i disable it so I can use my wifi laptop
XP
Goto network places in xp and in the left panel there is a phrase "Enable UpnP Devices" Click it. let windows go through the installation
now you may have to refresh but you will see the router. click on it and log in (password may be admin no password or something like that)
goto Wireless. setup as deezired.
Vista
same as xp but no need to Enable UpnP devices.
Failsafe.....
Press the reset button on the router and goto its config page like in the prior steps. Set-up as deezired.
hope this helps sorry if does not.
Aug 08, 2009 | Belkin (F5D7231-4) Wireless Router
Belkin 54 Wireless Internet Connection Problems
If wireless adapter on the laptop is fairly old, you may need to update the drivers for the wireless adapter. Some older wireless adapters are not capable of properly communicating with WPA devices. Typically a driver update of the laptop resolves the issue. If not, try another wifi adapter and verify it is not the OS or laptop itself.
Good Luck.
Jun 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin wireless G router and MicroNet Realtek RTL8187B USB
I got the answers (for free) from Belkin's excellent technical support.
Many thanks.
Jun 18, 2009 | Belkin (F5D7230-4) Router (587009)
F5d7230-4 router
The driver software that you are installing is probably not for vista
Try to download an updated version for vista
Dec 02, 2007 | Belkin (F5D7230-4) Router (587009)
Wireless Adapter not working under Vista
Some device may not have Vista drivers or the drivers are still beta and they dont work always perfectly. Check which kind of wireless adapter is present on your laptop from device manager on XP. Then try downloading Vista drivers for your wireless adapter form wireless card factory website, and install them on Vista.
Nov 04, 2007 | Computers & Internet
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
44 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
