chemical injectors are terribly designed, Flimsy to say the least. They all use a check valve (ball bearing) held agaunst a steel seat by a tiny spring. Yours is either stuckshut or rotted away from using bleach and not cleaning it well.Feel free to take it apart, clean, inspect and re assemble, If its a low cost machine like a troy bilt or any other that uses an aluminum pump your probably wasting your time. Use a hand sprayer like the one you use for weeds and have someone else spray the chemicals while you use the washer with water only
Husky 3000 pressure washer, Axial Cam Pump Diagram , need to take apart to clean caked soap out....
(More)
Husky 3000 pressure washer, Axial Cam Pump Diagram , need to take apart to clean caked soap out. model# HU80432
i have a karcher g 2600 vh i wasnt getting pressure and i found that my spill valve was faulty it...
(More)
i have a karcher g 2600 vh i wasnt getting pressure and i found that my spill valve was faulty it was actually broken i bought a new one installed it and im still not getting much better pressure ive taken the pump apart and checked for build ups blew thru the valves wirh the compressor and there appear to be no blockages
I have a model PW 2200 gas pressure washer. It suddenly lost it's high pressure the other day after...
(More)
I have a model PW 2200 gas pressure washer. It suddenly lost it's high pressure the other day after working fine for @10 minutes. It's getting plenty of water, but the engine doesn't seem to rev up to give it the high pressure. The operating instructions say to check the oil in the engine, and the PUMP before starting, but I haven't found any place to check for an oil level in the pump????Any ideas, I'm very confused.
