Home | Microsoft | Xbox 360 Console | When i switch my xbo...
Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
When i switch my xbox360 on there is no ound or
By rasouli2003 on Nov 07, 2009
when i switch my xbox360 on there is no sound or picture wot do i do
Solution #1
posted on Nov 08, 2009
Not Rated)
cooke2518
Rank: Guru  Microsoft Video Games  Expert
Rating: 86%, 28 votes
are there any red lights on your xbox if so this could be the problem:
e74 or rrod error means that there is an hardware issue.
What you need to do is a very simple and cheap repair.
look on ebay for x clamp repair kits, these are just a few bucks and most sellers include a good guide in how to do the mod/fix.
what causes the rrod or e74 error is the X shape clamp on the underside or the mother board bending and mis-shaping causing the ball soldering on the gpu/cpu slightly melting and forming hairline cracks in the solder.
The x-clamp kit will apply more pressure to the gpu/cpu and a little trick of disconnecting the fans and turning on the xbox and allowing it to overheat will re melt the solder ball joints to fill the hairline cracks.
Depending on which chip is the issue you may also need a 2000 watt heat gun instead of using the over heating method (the gpu chip).
Replacing the heat pads on the heat sink with thermal paste which comes with the kit will keep the gpu/cpu cooler and you wont have this issue again.
Please make sure you buy the kit which comes with heat treated nylon washers as the steel spring washes fail!.
The repair takes around 1-2 hours
I hope this helps in fixing you xbox.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
During xbox 360 systemlink play in COD4, the little white speaker will flash on the screen when you... (More)
Answer
Madden 2010 freezes while playing and sometimes while loading
Answer
im running vista and media player 12,went to xboxpcsetup and it said it wont run on my media... (More)
Answer
I am trying to play a game that needs an update but half way through the update it stops and says... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Xbox 360 Console:
Top Video Game Console Experts
Rank: Guru Guru
Solutions: 741
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Video Game Console Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
