sounds like you need to replace the upper and lower drum felt, they are probably worn. the upper felt part # is 134440200 and the lower felt part # is 134134700. the 2 parts together should be under $20.00. here is a breakdown showing you the location. hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire GLEQ2152ES Electric
The drum turns but there is no heat. I live 100's of miles from a technician, in Central America -...
(More)
The drum turns but there is no heat. I live 100's of miles from a technician, in Central America - I have taken out what I think are the fuses - parts 145160 and L222F. Do you think it is one of these? Can I use different part if I can't find these here? Thanks!!
My GE Gallery series dryer will turn but not heat. The light bulb went out 2 weeks ago, I doubt it...
(More)
My GE Gallery series dryer will turn but not heat. The light bulb went out 2 weeks ago, I doubt it is related. I have taken out 2 parts that look like fuses but can't find them on the net - 145160 and L222F. Are these fuses? Can I use some other part number for these - I live in Central America and I don't know if I can get the part. Thanks
Dryer was working fine, pressed pause, opened the door, removed a few items....closed the door, hit...
(More)
Dryer was working fine, pressed pause, opened the door, removed a few items....closed the door, hit start and now no heat??
