Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
Leaking water How do you unstop a defrost drain? I have water in the bottom of my refrigerator all the time......
  • 90 Answers
Inside of freezer, take back cover out and thaw the ice with hair dryer or hot water. don't use any sharp tools. When thawed make sure water drains through defrost drain.
Posted on Jan 05, 2008
Why does my samsung fridge leak water under the fridge when I use my water dispensor?
hi Todd.
Problem: It's leaking water. ... Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leakingout of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself - CNET
https://www.cnet.com/.../three-common-refrigerator-problems-you-can-easily-fix-yourse...
Why is my refrigerator leaking water from the bottom?If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013SOLVED: Water leak in refrigerator? - Refrigerator - iFixithttps://www.ifixit.com/Answers/View/128713/Water+leak+in+refrigeratorSearch for: Why is my refrigerator leaking water from the bottom?
Why does samsung fridge leak water under the fridge Google Search
Nov 27, 2017 | Samsung Refrigerators
Bottom of freezer has a layer of ice, that returns after removal, no aparent drain or leak
there is a drain hole in the bottom of freezer near back wall if its a side by side. take out bottom crisper drawer to locate drain. than take hot water in a turkey baster and run hot water doen drain hole to unstop drain.
Aug 31, 2014 | KitchenAid KFXS25RYMS 25 cu.ft. french...
My fridge is leaking water down the back into crisper
The defrost drain is stoppped up. The easiest way to solve this is with a compressed air tank. At the back of the ref. at the bottom you will see a hose leading into a drain pan.Blow the air through the hose and it will unstop the drain.Hope this helps !
Sep 29, 2017 | Whirlpool GT1SHTXM Top Freezer...
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
Water is collecting in the bottom of the refrigerator below the drawers. Water was also in the lunch meat drawer.
Your freezer defrost coils are probably frozen. Or the drain tube is plugged. Remove the rear panel from the freezer and defrost the defrost coils if necessary. Make sure that the drain tube underneath the coils is not plugged with ice or other foreign matter. You may have to thaw out the tube. If you don't make sure that the tube is clear, excess condensate will continue to drain into the fridge. Good luck!
Sep 21, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Water builds up under crisper bin then leaks on floor
unstop defrost drain under evap in rear bottom of freezer
Jul 05, 2009 | GE Refrigerators
How to unstop drain
If there's a drain, a shop vac will clear it. If no drain, you're getting too much condensation inside the fridge. Check the door fit, make sure no one is leaving the door open too long. If your freezer is overflowing into the fridge, a manual defrost may clear the problem. That takes a long time, have somewhere else for your food.
Apr 11, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
How do you unstop the drain line
Remove the freezer back wall and lower panel. Remove the visible ice. Use a hair dryer to defrost the drain hole in the rear trough.
Mar 13, 2009 | GE Refrigerators
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
156 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
