Question about D-Link DGS-2208 8-Port Gigabit Ethernet Switch (DGS2208)
Won't allow connection to router
Recently I upgraded from a Linksys WRT54G router to a Netgear WNR854T router. I had the "main" computer connected to the router through a generic 8-port 10/100/1000 switch. Setting up the WNR854T router, I had to disconnect the switch from the connection. After getting internet connection through one computer that used to go through the switch, I reconnected through the switch. The computer would not establish a connection. Thinking it was a switch problem, I bought a D-Link DGS-2208 switch and replaced the generic one. Alas, still the same problem, I cannot get a connection to the router via the switch. I went into Network settings and changed the Media type from "Auto-Sense" to both 100MBS Full Duplex and 100MBS Half Duplex, still no success. The network card driver is a Marvell Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller (card is "built-in" an ASUS A8V Deluxe MB)
  • Anonymous Feb 26, 2009
    Switch lock up and power cycle will not reset the switch unless the network connections are removed.
    Joe
I have a similar issue with a D-Link DSG-1005D switch. However, what I can tell you is that buying a crossover cable is a waste of money, as all Gigabit connections by specification are auto-sensing. If I find out the overall answer, i'll let you know, as I'm still looking.
Posted on Aug 22, 2012
    Novelist:
  • 139 Answers
Since each of these devices is rated for 1000Mb/s, everything should be compatible. Make sure the NIC driver is up-to-date on your computer....and use automatic settings for speed and duplex wherever you have the option of setting it. The only other thing I can think of is to try a "crossover" cable between the router and switch...although this function is usually handled automatically in most modern interfaces.
Posted on Jan 10, 2008
THE WI-FI FROM NETGEAR DOSNT WORK
What is the model number of your router?
Is it Linksys or Netgear. You have selected Linksys router and you are asking about Netgear router?
Please explain the problem in details.
How many wired and wireless computers do you have?
Do you have any computer wired to the router?
Can you access the Internet on the wired computer?
If the wired computer is also not working then I think you many need to check the Internet connection on the router.
If only wireless computer is not working then you should check the wireless settings on the router and the computer.
What is the operating system on the computer?
I can suggest you few websites which may help you.
Try Fix Home Network
Try How to connect to the Wireless on your computer
May 19, 2012 | Linksys Wireless-G WRT54G Router
Looking for an updated firmware version for model WRT54G
Upgrading the router's firmware will give it numerous functions. This includes a more stable connection to the internet.
To upgrade the router's firmware, complete the following steps:
i. Downloading the Firmware
ii. Backing-Up the Router's Settings
iii. Upgrading the Router's Firmware
iv. Completing the Firmware Upgrade
v. Restoring the Router's Settings
vi. Completing the Firmware Upgrade Process
NOTE: Before proceeding with the upgrade, your computer must have an active Internet connection. It is also recommended that you use a wired computer in upgrading the router's firmware.
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
Slow connection, how do I fix it?
Reduce the MTU settings on the router. You will need to open the set up page of the router. On the set up page , you will find the MTU set to Auto. Change it to manual and change the size to 1400. save the settings.
Also upgrade the firmware of the router.
Do you have any computer connected to the router ? If not then connect the computer to the router. download the firmware of the router.
Upgrade the firmware.
After upgrading the firmware , you will need to reset the router.
Once you reset the router, it will lose all the settings and you will need to reconfigure the router.
Click here
step by step instructions
Mar 31, 2010 | Linksys Wireless-G WRT54G Router
I have a Linksys WRT54G Ver2 router Problems
Try to upgrade the firmware of the router.
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. select proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
Click Here for more information about router and networking
Mar 07, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
Link HERE for more Linksys information
pls rate 4 stars
Dec 01, 2009 | Linksys Wireless-G WRT54G Router
I have a Linksys WRT54g which worked beautifully for 10months. I have an ethernet connection and used it for my PC and a laptop. Now it logs on and off every couple of secs. I tried resetting the whole...
If you disconnect the router , you are able to go online. Go to the Linksys web site. www.linksys.com/download and download the Firmware of the router.
You will need to select the correct model number and the version number of the router.
The model n umber and Version number will be on the back side of the router. You will see model number in small letters like WRT54G and just after that you will see V 5 or V6 or V8. this number will be the version number.
Download the file on the computer.
connect the computer and the modem to the router again and open the router set up. Upgrade the firmware.
Click Here to know more about how to upgrade the Firmware.
Nov 18, 2009 | Linksys Wireless-G WRT54G Router
No print sharing. Existing but lder Belkin router has no problems, but WRT54g-TM will not print share. Have a Netgear switch box as well, can I integrate the two or even all three to solve print share...
If you are using a belkin router, wrt54g-tm and netgear switch box. Basically they won share the printing. you need a wireless print server..try the linksys WPS54GU2
Jul 28, 2009 | Linksys WRT54G-TM Wireless Router
Intermittent/non-existant connection with LinkSys WRT54G router
I would get a Range Expander... it sounds like you are having problems recieving a constant signal. When you do get the range expander plug the Range Expander halfway between you upstairs computers and your downstairs where your router is at. I hope this helps!!
Sincerely,
cdixon18
The ManInsideTheMachine
May 19, 2009 | Linksys Wireless-G WRT54G Router
Router stopped working altogether
Please check your cable connections; are the lights blinking? try connecting your computer directly to the modem dsl port that is connected was to the router if connection can be restored.
Nov 11, 2007 | NetGear WNR854T Router (WNR854T100NAS)
D-Link DGS-2208 8-Port Gigabit Ethernet Switch (DGS2208) Logo
470 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
