Solonoid assembly probably went bad. Can purchase part and install yourself if you are somewhat mechanically inclined. Same part functions for both ice and water. Good appliance repair shop should have or be able to order the part
Those filters are for refrigerators that have heavily treated water in the household. You could have a filter that filters your water supply and not use the filter inside the frig. Why use both? Now, if your home is not filtered, you may need it. Check to see if the water supply line is crimped somewhere or frozen when it gets inside the frig.
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Hello. Hollow cubes is caused when there is not enough water going into the ice cube molds. That said, since you have too much water going into the water dispenser I would suspect that the valve needs to be cleaned or possibly replaced. Joe
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
afraid that sounds exactly like the problem.brand new fridge call who you bought it from they should fix it for free good luck hope this solves your problem
