Question about Frigidaire FGB24S5A Gas Single Oven
Fiigidaire gas oven trips power when I turn oven on
We had power cut recently. Since then the oven part of our Frigidaire will not ignite.
If I reset breaker on the wall then the clock comes on and the gas stove top lighters work. But if I turn the oven on and set a temp as soon as it tries to let gas flow the power trips again.
Any thoughts?
Thanks folks!
  • Anonymous Mar 29, 2014
    breaker trips when reset trips immediately
    breaker trips immediately
  • 640 Answers
Disconnect the wires going to the oven ignitor,turn the unit on see if its trips.if so the ignitor is shorted if not then disconnect the wires that go to the coil of the gas valve and do the same.i think either one of these is your problem.also if theres a fan in the oven do the same.
Posted on Jan 06, 2008
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Frigidaire gas oven not heating. The broiler and burners work but the lower burner will not ignite. I replaced the igniter however that did not fix the problem. In fact, the new igniter does not glow. I...
Check for volts to the new ignitor. The ignitor draws current which opens the gas valve. If it is not glowing it is not drawing power. Test the ignitor,disconnected, with an ohm meter, it should be under 200 ohms.
Dec 28, 2013 | Ovens
Pleb30t8ccb
Good Afternoon Friend,
I see that your Frigidaire double oven, model# PLEB30T8CCB, is having trouble with the top oven not heating.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn the oven on to heat up, and if it does not, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 09, 2012 | Frigidaire 30 in. Electric Gallery Series...
I've got an amana gas oven range and just had the ignitor replaced. Everything seemed to work great afterwards for about 2 hours but then the breaker tripped. I let the oven cool down before I reset it...
What you want to check or have checked is if the wiring on the new igniter was accidently not properly insulated and some or the wiring is bare and touching metel shorting the breaker each time the oven is turned on.
Aug 16, 2011 | Magic Chef 9512 Electric Single Oven
The oven will not turn on or light
First check the power to the oven if the power is good look at the bake igniter I have seen it cause this same issue, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Frigidaire FGB24L2A Gas Single Oven
Oven does not light igniter glows but no flame
This happens when an oven igniter (glow bar) is bad. The igniter must draw enough amps to turn on the gas to ignite the flame. If you have a square shaped igniter use this part#5303935066 If your have a round shaped igniter use part#wb2x9154. These igniter will pretty much work universally for most gas ranges or ovens.
  1. Remove the racks
  2. Unplug unit
  3. Take out the screw holding the bottom pan
  4. Remove screws holding manifold where igniter is attached
  5. Remove manifold cut wires about 2in link from igniter and clean leads.
  6. Unscrew and remove igniter
  7. Replace Igniter with new one and fasten onto manifold
  8. Clean wires and screw on ceramic nuts to wires
  9. Tuck wires back and Reinstall all components
Test your new igniter. You might notice it taking a little longer to light up but that is okay.
Please let me know if this was helpful by rating me a 4.
Thanks so much have a great weekend.
Dec 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
Frigidaire Gas Oven
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition. You can get a replacement at an appliance parts store. If you have a friend or relative who is a heating/air conditioning repairperson they can test your current igniter. Good luck!
Jul 10, 2008 | Frigidaire FGB24L2A Gas Single Oven
FEFL78CQA FRIGIDAIR ELECRIC STOVE
Unplug your power cord from the socket outlet.
remove the back cover where the power cord connection is housed. visually check the connection, expose wire harness might touches the cover somehow. or the cover was dent that causes the bare wire to touched the cover. correct the dent if any, or tighen loose wire.assemble back cover. Reset your circuit breaker to your Stove because the pop sound might trip off your breaker. That should solve the problem.
Jun 28, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven Problem
Check power going to the electronic module in back of the display. If power there you have a blown module. If no power check for a blown thermal fuze.
Apr 08, 2007 | Frigidaire FGB24T3A Gas Single Oven
Frigidaire FGB24S5A Gas Single Oven Logo
197 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
