Uh oh, thats not good...i think your hard drive is burnt from overheating..Id send it away to microsoft(if you have warranty) for it to be fixed. Another reason is that you A/v cables may be unplugged. Good luck.
My Xbox 360 won't turn on. When I plug the power cable into the wall, the orange light on the power...
(More)
My Xbox 360 won't turn on. When I plug the power cable into the wall, the orange light on the power brick lights up as normal, but if you plug the other end into the Xbox, the orange light starts blinking. Any advice?
my xbox 360 turns on with a green light and the drive opens and i hear the disc spin, but i get no...
(More)
my xbox 360 turns on with a green light and the drive opens and i hear the disc spin, but i get no video or audio output with HDMI or with the component cables
I need to know how/if i can open my NAT somehow without using a router, since i use internet sharing...
(More)
I need to know how/if i can open my NAT somehow without using a router, since i use internet sharing through my computer and for some reason it has a strict NAT suddenly.... im using my blackberry as a modem to my computer
Had 3 rings of death on xbox 360. took xbox apart, reapplied arctic silver to CPU and GPU, to no...
(More)
Had 3 rings of death on xbox 360. took xbox apart, reapplied arctic silver to CPU and GPU, to no avail. then replaced the xbrackets with better hardware to keep the heatsinks in contact with CPU/GPU. now, when the xbox boots it IMMEDIATELY shows 3 red lights, which flash 2 or 3 times, and then it turns to 2 red lights. the fans run very loud for 5 - 10 seconds, and shut off. it seems that the whole system shuts down, the heatsinks and CPU/GPU do not get warmer. running out of ideas here.....going to try shortly to use a different power brick. open to any and all ideas, please help!!!!
