Question about JVC GR-D250 Mini DV Digital Camcorder
JVC GR-D250 not recignize using firewire windows vista
I just got new PC. My JVC GR-D250 digital video camera was working with windows xp using USB. I tried to connect using firewire but nothing happen on pc side.
How can I know, what is the problem?
Is it require to install any driver for vista? If yes where can i get it?
I never used firewire before. What should happen when i connect the wire
and turn on the camera. I assume it will be same like usb...new hardware found etc. Or driver not recognze etc.
But in my case it is not giving me any messages.
plz guide me, thanks,
  • 1 more comment
  • Anonymous Aug 27, 2008
    Until recently my camcorder was working OK, but when I went to capture my latest video, my Pc is not showing it as installed. I have changed the Firewire cable, but the problem persists
  • keithcook06 Aug 27, 2008
    My PC has stopped responding to my JVC GR-D250 recently. When I connect the Firewire cable to my camcorder, I get 3 tones from the PC but no New Hardware found window. I have changed the firewire but the result is the same.
    regards,
    Keith Cook
  • Anonymous Sep 01, 2008
How do you put it in memory mode. I have the same problem.
Posted on Oct 23, 2008
  • 156 Answers
Put it in memory mode and try.if it showing there is no any problem with camera and you pc,because this camera when it is in cassette play back mode it is not supporing with pc.
Posted on Jan 22, 2008
Have HP Pavilion running windows vista. will not recognize camera
Use firewire(DV terminal), some JVC models do not support USB streaming. Good Luck
Mar 08, 2010 | JVC GR-D370 Mini DV Digital Camcorder
How can I download the recorded media to PC having windows xp?
you need a firewire cable (ieee1394).
you also need a firewire port on your pc. if you don't have one then you can buy a firewire pci card.
they are not expensive.
Jan 22, 2010 | JVC GR-D250 Mini DV Digital Camcorder
Fire wire to PC Express
yes...al so known as ieee 1394 ..or fire wire ...or greyhound....it might though prompt you for a driver ...
http://en.wikipedia.org/wiki/FireWire
Jul 18, 2009 | JVC GR-D250 Mini DV Digital Camcorder
Connect jvc GR-D720E TO WINDOWS XP PROFESSIONAL EDITION COMPUTER
looking for usb cable for camera to computer for model no GR-D720E
Jun 01, 2009 | JVC GR-D250 Mini DV Digital Camcorder
I have a JVC GR-D250 camcorder. When I connect firewire cable (that has come with the camera) to the PC it gives message "USB device not recognised". If I check the Device Manager it shows "Unknown...
You should have a DV Cable 4-pin to 4-pin firewire (part number VC-VDV204U ) which came with your camera. It would not have firewire on one end and usb on the other. They are two seperate technologies. see http://www.wisegeek.com/what-is-a-firewire-to-usb-adapter.htm
May 02, 2009 | JVC GR-D250 Mini DV Digital Camcorder
Record directly from jvc model GR-- D370U Digital Video Camera to my pc
Sorry, but it's not possible to record directly to a PC. Windows movie maker will only record from a tape. Please use a quality cable like Belkin, I have had issues with the cheaper firewire cords.
Good luck
Oct 07, 2008 | JVC GR D370US camcorder Mini DV
JVC CAMCORDER DRIVERS
its true that normally you don't need to download the driver, however when it does pop up, i'd say go here http://members.driverguide.com/driver/detail.php?driverid=87522 and just download the zip file for the drivers.
Jun 02, 2008 | JVC GR-D250 Mini DV Digital Camcorder
JVC camera software GR-D70 for windows vista
Like most I have searched the web for drivers, preferably free ones. I emailed JVC Australia who responded with tis solution.
The camera has a connection called DV. The DV connection is used with a cable called Firewire.
Firewire is a driver less cable and will allow you to stream you video footage across from the camera to your PC.
USB is used for data transfer and need drivers, you would use this mainly to transfer still images or data files off a HDD camera.
If you use firewire and the DV connection you will stream the footage across to the PC and the PC will capture the footage as it is playing.
The firewire is about $15 and can be purchase from stores such as **** Smith, Bing Lee, Harvey Normans and Tandy. I would suggest that you take a photo of the connections on your PC as there are two types of DV connections. (4pin - 6pin)
Feb 12, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
My camcorder
Mt computer with Windows Media, Premiere Pro 1.5, Imagewriter and a few other cannot see my GR-D250. I bought the correct firewire cable, plugged it into the cam and then the comp, nothing, no "new hardware detected", nothing, Screen is open, cam is on Play, blue screen working, nothing. I'm going to my room now.
Dec 26, 2007 | JVC GR-D250 Mini DV Digital Camcorder
JVC GR-D370 DV Camera Compatability with Firewire card problem
I loaded it successfully onto my ACER laptop via the built-in firewire. No problems whatsover. Any firewire card should work. Are you having a specific problem?
Sep 23, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
249 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
