Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Problem for Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Fride not working freezre works and the defrost
By jose3307 on Nov 07, 2009
fride not working freezre works and the defrost times is aways on what do i do.
Solution #1
posted on Nov 08, 2009
Not Rated)
salde386
Rank: Guru  Kenmore Refrigerators  Expert
Rating: 94%, 45 votes
try advancing the timer with a staight blade screw driver turn it slowly till it clicks and see if it goes into defrost,if so you have a bad timer,open freezer door do you hear the fan blowing,if not you could have a bad evap fan motor,is there ice or snow on back freezer wall,if so you have a defrost problem,timer,t-stat heater or fan motor you need a meter to read them out to see what is bad next time send model number
Comments:
Nov 08, 2009
- you could have an adaptive defrost board instead of a timer but i need the model number to check hope this helps
Was this helpful?
Yes
No
Popular Solutions for Kenmore 20.6 cu. ft. Top
Questions and Unsolved Problems for Kenmore 20.6 cu. ft. Top
Do you recommend Kenmore 20.6 cu. ft. Top Freezer Refrigerator?
Answer
Answer
hello i have a kenmore fridge and it wont get cold neither will the freezer but, i can hear it... (More)
Answer
I need to know how to fill the bobbin for my Kenmore Model# 148 15600
Answer
water leaks inside,cant seem to locate drain. Water freezes in bottom of freezer,then runs down to... (More)
Answer
The ice maker was not shut off for 2 months and freezer was frozen in all vents. When all thawed and... (More)
Answer
i would like to change the direction the doors open but no do have a manual
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 20.6 cu. ft. Top...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
