Question about EliteGroup K7AMA Motherboard
Bios Update??? I have a Athlon XP 2000+ and when i use it at full speed 1.67 Mhz after a while it's restarting, If i use it at 1250Mhz it's working. What kind of memories can i put on this motherboard?
  • sm3ch3ri3 Jan 05, 2008
    sorry for the writing mistakes "what kind of memory card can i put on this motherboard"?
    Scholar:
  • 47 Answers
Hi sm3ch3ri3,
Take a look at this page, it has all the information on the motherboard and a download link for the manual. In the manual you will find the information on the memory speeds and types you can use with this motherboard.
It might be worth looking at the BIOS setting section so that you can get your processor running at full speed. Also you may need to update the BIOS in oder to get the processor running at full speed.
Regards,
Spare head 2
Posted on Jan 05, 2008
What is the upgrade cpu for this motherboard
The following processor are currently supported by this mainboard.
Athlon XP: 1500+ up to 2000+; FSB: 266 MHz
Athlon: 650 MHz up to1.4 GHz, FSB: 200 MHz or 266 MHz. Socket A CPU. See page 10 in you're manual (If you still have one). After going to Elitegroup and checking for the latest bios version;
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=67&CategoryID=1&MenuID=50&LanID=9
BIOS for K7VMM(PCB:1.2A). Release date, 2003/03/28
The MB will support, AMD Athlon XP 2400+ and 2600+ CPU If you're bios is flashed to the above. You can buy and use this CPU; http://www.sjkksales.com/servlet/the-461/AMD-ATHLON-MP-2600/Detail
Never flashed a bios? Instruction are listed on ECS web site.
Mike
Jun 13, 2010 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
How to upgrade processor on ASUS A7A266 motherboard?
looking at this old motherboard the 2400 is unlikely to work, the motherboard has a cpu fsb support of 133mhz and supports the duron processors.
offhand, 2400 wont work.
Mar 18, 2009 | Computers & Internet
Processor speed loss
It's possible that the XP is using the extra resource or processor usage, and there isn't anything that you can do. However, It's also possible that this machine was configurated for 2000, and that it just needs drivers for XP. You can start by going to IBM's support site and doing a bios flash to the most recent bios, and checking for a chip set driver update, patch, or for for XP. Also check for any processor speed stepping drivers or updated drivers. Try this and let me know.
Aug 19, 2008 | IBM ThinkPad A21m 2628 Notebook
Motherboard Jetway V880DAS, PCU Athlon xp 2800, Memory PC 3200 2Gb. Bios Update 880DASA7.BIN .Operating system Windows XP Pro with Service Pack 2 I Set the CPU FSB Jumper to 166 Mhz.The computer keep...
is this the first time you encounter this problem with the athlon Xp? i have encounter this already with my PC. you should update again the bios of your computer, and load the setting of your bios to the default settings.. try to restart your computer.. and try to contact me as soon if this works for you. thanks!
Apr 15, 2008 | Computers & Internet
AMD Athon XP 2600 dropped speed
Some times when a computer shuts down unexspectedly like that it will reset itself back to its defaults in bios thinking there was a problem. Go in there and check your cpu settings. The fsb should be set to 266 mhz. Make sure it didnt default back to 133 mhz.
And FYI the 2600 is acutally a 2.13 gig cpu not a 2.6 gig..
Mar 02, 2008 | AMD Athlon XP 2600+, 2.08 GHz...
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
amd 3200 + anthlon ok with fsb 266 mhz soket a
Jan 10, 2008 | ASUS A7S333 Motherboard
RAM not running at full speed
Go to page 33 in your manual, see DRAM Clock/Drive Control & press enter. You can tweak your memory to run faster however your manual suggest not too. Hate to see you burn it up. As you will see everything is set to Auto:
Max Memclock (Mhz) [Auto]
1T/2T Memory Timing [Auto]
CAS# latency (Tcl) [Auto]
When DDR Timing Setting by is set to Manual, use this item to set the DRAM frequency. Would be nice to have a side panel fan blowing on your memory.
Link to your board.: http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=455&DetailName=Specification&MenuID=1&LanID=9
Jan 04, 2008 | EliteGroup K8M800-M2 Motherboard
PROCESSOR
Unless you can upgrade your bios chip, you can only go to
(Socket 462) AMD® Athlon/Athlon XP/Duron processor up to 2000+MHz.
If you upgrade your bios to version 1.1
You can run the XP 2200+ , Socket A.
Dec 19, 2007 | MSI 745 Ultra (MS-6561-010) Motherboard
PROCESSOR
Your M/B support Socket 462 (also called Socket A) is a PGA socket designed for AMD K7 family of processors. This socket can be used with AMD Athlon and Duron processors ranging in speed from 600 MHz to 2200 MHz (3200+) and with bus frequences ranging from 100 MHz to 200 MHz (400 MHz DDR)
Athlon (Socket A) (600 MHz - 1400 MHz)
Athlon XP (1333 MHz - 2333 MHz, or 1500+ - 3200+)
Athlon MP (1000 MHz - 2133 MHz)
Duron (550 MHz - 1800 MHz)
Sempron (socket A) (1500 MHz - 2200 MHz, or 2200+ - 3300+)
Mobile Athlon 4 (850 MHz - 1400 MHz)
Mobile Athlon XP-M (Socket A) (1200 MHz - 2200 MHz, or 1400+ - 3000+)
Mobile Duron (650 MHz - 1200 MHz)
I Recommend to go for Athlon XP with good cooling fan. :)
Dec 18, 2007 | EliteGroup K7AMA Motherboard
Athlon 2800+ XP-M runs at 606 MHz
1. Check your battery, 2. Press CTRL+F1 or ALT+F1 while you are in the BIOS. 3. Update your BIOS Microcode and CPU Code.
Sep 20, 2007 | AMD AXMJ2800FHQ4C - Athlon 2800+ XP-M...
EliteGroup K7AMA Motherboard Logo
74 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
