Loud noise when spin drying, rumbling sound, sounds like concorde taking off! Hotpoint Aquarius 1200 washer dryer WD62
  • Washing Mach... Master
  • 3,463 Answers
Remove rear panel of washer, and remove drive belt.
Spin the drum by hand, and if it feels rough, or is noisy, then the main drum bearings have failed, quite a big job to do.
Please rate my solution.
Thanks.
Posted on Nov 07, 2009
SOURCE:
Hotpoint 1200 wd62n banging noise when loaded but ok when its empty ?
There are many reasons that this could be noisy...
When you turn the drum (quickly) when it's empty does it rumble? Bearings, drum support or motor bearings.
If it sounds like a pneumatic drill when filled and spinning it could be drum support, bearings, balance weight or suspension.
These are not an exhaustive list but the usual suspects.
Jun 02, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Very noisy when Hotpoint Aquarius WMA46 is on spin
It is the main drum bearings that is causing the noise.
There is no provision made for lubrication.
It can be done as a DIY fix, but it is a very involved repair, as it means having to remove the whole inner workings of the washer,
Not a task I would recommend unless you know what you are doing, and feel competent to tackle it.
Good luck.
Dec 05, 2009 | Hotpoint Washing Machines
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Noisy spin on hotpoint wd62
comon fault on hotpoints is drum bearings put ya hand in the drum and give it a quick flick if it soundslike it rumbles buy a new washer.since merloni bought hotpoint you prob have to buy a whole drum not just bearings
Oct 03, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Washer WF320 1200
It could be that the drum is coming loose and a bolt requires tightening. I would suggest that you cease use until you get this fixed. Yell.com will provide you with choice of qualified engineers who can assess and repair.
Aug 05, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
Aug 14, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Washing Machines Logo
269 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
