Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
Posted on Nov 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The brush doesn't spin anymore, but the belt is not broken. model DC 07; approx three years old
Anonymous
Level 3:
  • Master 701 Answers
  • Posted on Nov 07, 2009
Anonymous
Master
Level 3:
Answers
701
Questions
0
Helped
298523
Points
1875
The belt may not be broken but after 3 years the belt will have stretched and it will not turn the brush. You should change the belt every year. Changing the belt is an inexpensive fix. I would try that first and if it doesn't do the trick I would take it to a repair shop. You can get the belt you need here:
Dyson DC07 Replacement Belts
Why has new belt on DC 07 broken immediately after replacing
check and clean the brush bearings located on each end most reasons that belts break is the brushes are binding from debris --others bad belt or old and dried out
How do I fix the carpet brush on my dyson dc14 vacuum?
this is what is is broken it is the clutch Dyson clutch belt assembly for DC07 amp DC14 900252 04 473
most likley needs to be changed it is also a good idea to change the roller brush at this point also
Dyson Dc 07 14 33 Upright Models oem 904174 01
1helpful
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 • Vacuums
We are trying to replace the belt on the bissell 89q9 model. We purchased belt 8 and got in onto the brush however the brush doesn't spin anymore. Even trying to turn it by hand doesn't work. One...
Remove the beater brush assy & remove the
shaft & brgs that go through it 7 clean out the
hair,fuss ect,so it will turn
You need to take your vacuum apart once a year or more
to clean things so they continue to work
May 22, 2011 • Vacuums
1helpful
Belt burned up (first time); installed new belt but that starts to burn also; approx. 2 years old
Sounds like the brush that the belt is supposed to turn is bound up tight. Need to remove the brush and clean all debris from it. Where you can get at the center rod for the brush, the rod that the brush spins around, clean the ends and add some WD40, being sure not to get it on the belt. This should remedy the problem of the belts burning as long as the belt is put on correctly.
2helpful
2answers
Brush doesn't spin
This model has Brush Control
The Brushbar can be turned off to protect rugs and delicate floors
You've either accidently turned the brushbar off or the belts broken
I have a dyson - bought it 3 yrs. ago and the roller brush stoped working - doesnt pick up anything. Can you help? The brush doesn't roll or spin. Where can we take it to be fixed and is it under warrenty?...
Don't worry it's probably just that the belt has broken or stretched. Your actually supposed to change them yearly. So if its been three years thats probably the case. Here is a link to the belt you need and a manual with instrutions:
Dyson DC07 Belt and Manual
The bottom brush that spins around is not moving anymore
The belt that drives it has probably broke,If you can remove the head on that model remove it and replace the belt . You make have to access the belt by removing the screws from the bottom of the power head.
Aug 18, 2009 • Vacuums
2answers
Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
