Question about Maytag MZD2669KE Side by Side Refrigerator
Water is is leaking out the water dispener non stop, so I had to cut the water valve behid the refrigerator off. Why is this?
  • Anonymous Apr 12, 2008
    Does anyone no where to get the parts schematic for Maytags? I am sure I can shange the valve myself but do not know were it is. The water lines disappear into the refrigerator.
  • 90 Answers
Bad water valve, selenoid not closing all the way. Replace water valve. Part# is 67005154
Posted on Jan 05, 2008
GE water line from refrigerator to the valve is leaking
This is a non standard tubing and you may be missing ferrules. The fixture on the valves may have a hairline crack.
Feb 04, 2018 | GE GSS25LGM Side by Side Refrigerator
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
Water dispensing but also leaking from the back
Pull the fridge out and remove the back panel . Have someone press the water dispensor and watch for the leak . Usually , the plastic line at the water valve breaks off , and removing the broken piece and reinserting the line , fixes it . You may have to remove the 1 screw holding the water valve on , to gain access to remove the broken piece of line . The water valve itself , could also have a hole in it , spraying , due to long period of water pressure . Just replace the water valve , if this is the problem .
Sep 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
My refrigerator water dispener is dispensing jelly like stuff !
run it until the water comes out clear and replace the filter trice.
Mar 30, 2009 | Maytag MSD2756G Side by Side Refrigerator
Slow water dispener
there s a motor present for the working of the water dispenser whose rpm would be slow due to which the water dispenser is slow so change tat motor or repair it and then use it after tat it will work properly
Jul 22, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Leaks after it dispenses water
try running 8 cups of water through the dispener. there may just be air in the water tank. after it was installed the people that delivered it should have done this but most of them dont
Nov 21, 2007 | LG LFD22860 Bottom Freezer French Door...
Maytag MZD2669KE Side by Side Refrigerator Logo
61 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
