I have a Hotpoint HTR16ABSARWW Top Freezer Refrigerator in my garage. With the cold weather we are...
(More)
I have a Hotpoint HTR16ABSARWW Top Freezer Refrigerator in my garage. With the cold weather we are having in Atlanta, the freezer has turned off. What do I need to do?
I have a Jenn Air side by side fridge. Recently, I had to replace the ice maker....
(More)
I have a Jenn Air side by side fridge. Recently, I had to replace the ice maker. Installed it a week ago, and everything seemed fine. Today, it has started discharging water out the water dispenser when the ice maker is going through it's fill cycle. I get some water in the ice tray, and also water spraying out the water dispenser onto the floor. HELP!
Amana afb2534dew- The fridge is running only on the lowest temp (I have it set at hightest). My...
(More)
Amana afb2534dew- The fridge is running only on the lowest temp (I have it set at hightest). My freezer is fine.
Hi, I have a Hoover 2605A-L80 fridge freezer unit. The freezer compartment seems to be working fine,...
(More)
Hi, I have a Hoover 2605A-L80 fridge freezer unit. The freezer compartment seems to be working fine, the problem is that the fridge is far too cold. I assume this is caused by a faulty thermostat or a valve somewhere not closing probably and therefore continuing to allow cold air from the freezer into the fridge compartment. For all the cost they are I intended on replacing the thermostat to try that but have not been able to locate it in the unit! Does anyone know how to access it? Does anyone know how to check/fix this?
Need to install new housing above the filter because the old one is cracked causing leaks. How do I...
(More)
Need to install new housing above the filter because the old one is cracked causing leaks. How do I remove the water lines to the old housing?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
