Samsung LN-S4051D 40 in. LCD Television
Problem for Samsung LN-S4051D 40 in. LCD Television
Need to remove the voltage inverter for a Samsung
By rmartin868 on Nov 07, 2009
Need to remove the voltage inverter for a Samsung LN-S4051d LCD TV. The board will lift up from the metal casing it is fastened too. But the lamps inside the casing will not come thru the holes in the casing. I know they are delicate so do not want to force. How do you get the inverter board off?
Comments:
Nov 07, 2009
- Yah, I tried to be ever so gentle but those lamps are pretty delicate. I give up. I now have a Samsung lns4051 lcd tv available for parts. going to buy a Sony. thanks for your help.
Best Solution
posted on Nov 07, 2009
Very Helpful)
broadbents1
Rank: Wiz  Samsung Televisions & Videos  Expert
Rating: 84%, 45 votes
the inverter comes out by levering out ( NOT LIFTING ) of light holders start at top ( THIN SCREW DRIVER ) will do TAKE YOUR TIME
Comments:
Nov 07, 2009
- A little heavy handed ? don't know were to got tubes from and i know it is easy-er ot replace screen instead of striping screen down
Nov 08, 2009
- THE INVRETER BOARD COMES OUT OF LIGHT HOLDERS (DO NOT TRY LIFTING HOLDERS OF LIGHTS)
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks that worked. Unfortunately they all came up ok accept for one in the middle of the board where one of the lamps broke off. Bad. Now what? " - rmartin868
Popular Solutions for Samsung LN-S4051D 40 in. LCD
Questions and Unsolved Problems for Samsung LN-S4051D 40 in. LCD
Do you recommend Samsung LN-S4051D 40 in. LCD Television?
Answer
Answer
screen is green when first turning tv on or when i switch modes. ex from hd tv to component
Answer
Samsung lcd tv front case melted TV works with round colorful circle on screen above where case is... (More)
Answer
Samsung 40" Model LN-S4051D now has a pink thin pink strip of light going horizontally thru the... (More)
Answer
The manual for my new 40" Samsung LED backlit TV doesn't tell how to assemble or put the TV... (More)
Answer
my tv powers on flashes blue solid screen and then nothing but multible color lines
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
