Refrigerators
Problem for LG Refrigerators
Generic problem for all LG Refrigerators
VEGETABLES FREEZING IN LOWER LEFT DRAWER
By findley8741 on Nov 07, 2009
VEGETABLES FREEZING IN LOWER LEFT DRAWER. I have an LG model LFX25960. If I raise the temp to 45 in the refrigerator it will be 34 in that drawer but that also makes the rest of the refrigerator too low a temp.
Solution #1
posted on Nov 09, 2009
Not Rated)
mgprice
Rank: Guru
Rating: 96%, 453 votes
Hello, This problem is going to be the cold control, this can be located in the control panel inside the fridge. This part is also called the thermostat. What is happening here is it has opened and the freezer is getting to cold which is making the fridge too cold. This is why the food in your fridge is freezing. You should replace the cold control and you will be all set. Mike
Was this helpful?
Yes
No
Solution #2
posted on Nov 08, 2009
Not Rated)
jan mczeal
Rank: Guru
Rating: 88%, 270 votes
If the ambient temperature is below 41 degrees Fahrenheit, set the control to warm position. Do not put the vegetables near the cooling air outlet. Put them on the high-temperature section of the refrigerator or the front part.
Was this helpful?
Yes
No
Popular Solutions for Refrigerators
Questions and Unsolved Problems for Refrigerators
Answer
I am thinking of buying a used 2005 GE side by side fridge model GSS25XSRCSS. Any experience good... (More)
Answer
the samsung four door quattro refrigerator
Answer
Im having problems with a commercial manitowac ice machine and the problem is that it will... (More)
Answer
oster wine cooler-so how do you fix the wine cooler that does not cool
Answer
the refridgerator shuts down (no power-lights off) when the either door slams. loose connection?... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
