Apple iPod Video 30 GB Black  MP3 Player
Problem for Apple iPod Video 30 GB Black (MA446LL/A) MP3 Player
I have a blank screen and it does every thing else
By codys_0521 on Nov 07, 2009
i have a blank screen and it does every thing else exsept a screen it gives me a white screen but not like it was
Solution #1
posted on Nov 08, 2009
Somewhat Helpful)
hunter19_46m
Rank: Guru  Apple MP3 Players  Expert
Rating: 92%, 164 votes
This is probably caused by not allowing the firmware update to finish the installation before disconnecting the iPod. Try these steps.
Reset the iPod:
  1. Turn the Hold switch on, then back to off.
  2. Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
  3. You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following the next step. How exactly you check a charge on an iPod screen that is completely white has yet to be revealed. But hey, give it a shot anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
  2. Press and hold the Menu and Select buttons until the Apple logo appears
  3. Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Don't disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Good Luck,
Hope this helps
Was this helpful?
Yes
No
Popular Solutions for Apple iPod Video 30 GB Black
Questions and Unsolved Problems for Apple iPod Video 30 GB Black
Do you recommend Apple iPod Video 30 GB Black (MA446LL/A) MP3 Player?
Answer
Answer
i dropped my 30gb ipod video and the screen went black the ipod still works fine i just cant watch... (More)
Answer
usb driver download problem with my 30gb ipod it just won't come up in my itunes
Answer
why does my ipod touch read as a camerra only and how can i fix this?
Answer
screen is frozen,on the top of the screen it says SDRAM full test,tells me to please wait........... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apple iPod Video 30 GB Black ...:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 480
Experience: By using this stuff I know what I know when I know, but sometimes don't know how I know you know??
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
