Question about Mitsubishi WS-55805 55" Rear Projection Television
Mitsubishi 45" Projection TV
I am having this strange flickering problem with my projection TV ever since a power outage in my area...any ideas? I have a full color picture but it flickers and there are lines that appear in different places on screen clear across the screen...what gives? It's almost as if there's a short or something. Thoughts?
  • 59 Answers
You may need to replace the color wheel or the power outage may have damaged the DMD board too
Posted on Mar 23, 2008
Mitsubishi VS-45603 had power outage and when it came back on it says TV is locked. How do I unlock it?
Go into the 'Menu' -> then 'Setup' -> then 'A/V Connections'.
You should see an option called 'Locked to Input' switch it to 'No' and your problem should be solved!
May 05, 2011 | Mitsubishi VS-45603 45" Rear Projection...
I had a power outage and i can't watch my mitsubishi tv. How do i reprogram it so i can watch it?
Hi,check if power supply didn't get damaged, that's normally what gets damaged when there's a power outage.Sometimes it's just some capacitors that get damaged of the power supply.Have a bless one!
Apr 05, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Projection TV flickering blue screen, cannot access devices
Did you ever get this problem solved. I am having the exact same problem?
Nov 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Resetting the parental controls
I can help you unlock your Mitsubishi HDTV VChip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Feb 27, 2009 | Mitsubishi VS-60611 60" Rear Projection...
Green light continues to flicker, TV will not turn on or off.
Unplug it for 30 minutes. Then try again.
Let me know and I'll check the service manual. I've got a 65511.
Feb 01, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WD-52327 Picture flickers and goes blue
In your case I've seen this and it was a electrical issue between the DLP fan and board. The tv could have a problem with the digital tuner and not kicking a code due to low voltage ... it isn't expensive to fix, just hard to diagnose.
Do you smoke? The fans suck in smoke and it gets tar build up on the connections and that causes this in some cases too.
Dec 28, 2007 | Mitsubishi WD-52327 52" Rear Projection...
TV has sound but no picture
First do the self diagnosis test to see what area is effected, search threads here or goto
Dec 02, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Vs-45607 mitsubishi tv
Try Re-soldering the vertical yoke connections and vertical output IC. This is quite common with this model.
Sep 23, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
151 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
