Question about Apple iBook G3 Mac Notebook
Stereo connection What is the best option to connect my iBook G3/700 to my stereo for optimum sound quality?
    Novelist:
    Champion:
  • 382 Answers
2 options. It depends on whether you're using it for playback or recording. Keep in mind the signal is only as good as the file. So if, youre playing mp3 that are 128k, its realy not going to sound that great. YOu can run a stereo 1/8 m ( headphone ) to stereo 1/8 m, but make sure its not longer than 6ft. Also you can spend about $40 on something called an Imic made by griffin. This allows you to go usb2 to 1/8" m. Since youre running it to a stereo, which has volume control, you'lll have to do some adjusting on both ends, but make sure the signal is not too hot when youre patching to the stereo.stereo connection - 5de7e77.png You can go into ITunes/Preferences/Advanced/Importing, and check the sound quality your audio is set to import at. The higher the bit rate, the higher the resolution, the larger the file. So, it's give or take, and ideally your an external hard drive is where you would want to store your audio. Less stress on your hardd rive and processor(s) during playback.
Hope this helps, keep me posted.
Posted on Jan 08, 2008
  • Keith Seekwhensir
    Keith Seekwhensir Jan 08, 2008
    ANd the ibook only has usb 1.1 ( correction ). Either or, if you're playing mp3s, the audio is to compressed to achieve a stunning sound without patching a studio grade compressor and or parametric eq.
    Again, keep me posted.
6ya staff
SOURCE:
Wanting to hook up a sound bar to TV model
The cheapest way of connecting your flat screen and soundbar is to use the TV's headphone jack. It's not the best quality, but a lead will cost a couple of Pounds/Dollars and it will do unless you want the sound really loud.
If you want the best quality then the answer is to use the TV's Optical output. This sends a signal in digital form as a series of light pulses. This isn't directly compatible with the stereo input of a sound bar. There's no kind of cable or plug adapter you can buy that converts this just through a piece of wire. So you would buy an Optical to Stereo phono/RCA converter that can translate light pulses into a stereo signal. Here's a link to one from Amazon. It is less than 10 Pounds Sterling
Cable Mountain Digital Optical ToSlink Amazon co uk Electronics
Sep 10, 2014 | Televison & Video
Tip
How do I connect my iPod to a stereo Kenwood
<p>The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod. <br /> <p><br /> <p>1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see. <br /> <p><br /> <p>2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack. <br /> <p><br /> <p>3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected. <br /> <p><br /> <p>4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off <br />
on Aug 09, 2011 | Apple iPod touch
How do i connect a goodmans soundbar to an lg smart tv
If you want the best quality then the answer is to use the TV's Optical output. This sends a signal in digital form as a series of light pulses. This isn't directly compatible with the stereo input of a sound bar. There's no kind of cable or plug adapter you can buy that converts this just through a piece of wire. So you would buy an Optical to Stereo phono/RCA converter that can translate light pulses into a stereo signal. Here's a link to one from Amazon. It is less than 10 Pounds Sterling..
Sep 09, 2014 | Televison & Video
Latitude 640
To get best quality sound you don't need software but a good audio output. The sound quality of digital audio files is excellent. your cheapest option might be a good Bluetooth speaker (30 USD), you need a USB Bluetooth card but they are dirt cheap. Most expensive option is to connect output to a stereo amplifier with professonal speakers. I have thissolution and sounds great.
Apr 19, 2014 | Dell Latitude E6400 Laptop
I want to connect my mp3 player to either my soundbar or flat screen. How would i go about that?
Hi
You don't identify your make and model of MP3 player or your Flat Screen TV.
Some types of MP3 player can dock into a device (MP3 Dock) that has audio output connectors that can connect to either your TV or your Sound Bar with either standard stereo phono or HDMI cables (your TV has HDMI capability).
If no dock is available for your MP3 player, a stereo phono to 1/4 inch stereo jack will connect either audio Out or Headphone Socket to your TV or Soundbar. The sound quality may not be the best with this type of connection but it should be adequate.
A retailer like Radioshack, Best Buy, PC World, Maplin, etc. (depending on where you are) should stock these MP3 Docks and cables.
Hope this helps.
Aug 24, 2011 | Vizio VSB210WS Soundbar
CANT GET MY TV TO WORK WITH DVD PLAYER
Connecting a DVD player to your stereo receiver (or television, if you don't have a receiver) involves making two basic connections: audio and video.
Audio
The first connection to make is for the audio portion of the signal. There will be several options depending on the receiver you have.
  • The best choice (if available) is either to use an optical (also called Tos-link) or coaxial (RCA) digital connection. These two choices are equal in quality. In order to use either of these, you will need to have both an output on the DVD player, and an input on the receiver. Only receivers with built-in Dolby Digital decoders will have this type of input.
    The audio outputs on a DVD player
  • If your receiver does not have a built-in Dolby Digital or DTS decoder, but is "Dolby Digital ready," look for the 5.1-channel Dolby or 5.1-channel DTS. This connection involves six cables, corresponding to different speaker channels: left front, center front, right front, left rear, right rear and subwoofer.
  • The last option to connect the two components is with analog RCA outputs. This is a two-cable connection, with one cable delivering the left speaker sound, and the other cable delivering the right. This connection will deliver only stereo sound, but it may be your only option if you are hooking up directly to a television, or if you have an old receiver with only two channels.
Now let's take a look at the video connection.
  • The best quality choice is to use component connection. This connection consists of three cables: color-labeled red, blue and green. The quality is superb. However, these connections only exist on extremely high-end receivers and television sets.
    The video outputs on a DVD player
  • The next option is s-video. One cable connects the DVD player to the receiver in this setup.
  • The last option, similar to the audio setup, is to use the analog RCA video output, usually color-labeled yellow on both ends. This will deliver the lowest quality, but will suffice for most older, analog televisions.
Jul 03, 2010 | Symphonic Televison & Video
I have a C180 Kompressor Coupe. I wondering which
what stereo?
some mercedes have a 3.5mm stereo jack point hidden in the glove box.
There are devices available such as The Dension ice Link Plus is this an option to investigate? (plugs into CD changer socket on back of stereo and allows steering wheel control to work)
Is an after market stereo an option? does yours have an aux input? if there are red and white phono leads at the rear then you could run a 2x phono to jack plug lead straight to your ipod.
Jan 13, 2010 | Car Audio & Video
I am having problems connecting my laptop to my tv
Lots of people are doing this and part depends on what your home theatre has to offer in the way of connections.
For sound most use the LINE OUT on a computer or laptop and connect that to a suitable input on the receiver using a 3.5mm to stereo phono lead.
If you are lucky enough to have an OPTICAL sound out on your computer and one on the home system that would be a better option.
For the video side again it depends on what your computer has to offer
If it has DVI and your TV or home system has DMI then that is the very best option. remember to lower the resolution on the computer first and to check and of your graphics card options for dual display. A DVI to HDMI lead is needed for that
Nvidia graphics cards seem to work best in this area.
If you have a VGA connector on your TV that is another great option and you would only need a VGA lead.
Some cards and laptops have S-VIDEO out. Lots of TV's and home systems have these and the display is quite reasonable. If using S-video connections use a GOOD quality cable.
Some people can only obtain a black and white picture so check your graphics card did not come with any special adaptor.
Another method is composite video Even that is not always 100%
Some laptops need a special S-video adaptor which is just a short little cable to properly enable the S-video and convert S-video to composite. That is probably the worst way to do it.
Using a VGA to component lead is also an option but results vary wildly from no picture to quite good. A lot depends on the quality of the lead once again.
I use the optical sound and DMI lead to power a 50" Sony with great sound and picture.
Sep 21, 2009 | HP Compaq Presario F500 F700 and G6000...
Connecting a computer to a LX3600D Home system
Sep 19, 2009 | Philips LX3600D System
How can I connect my sony mp3 player to pioneer deh-5800mp in dash stereo
Hello nmfsc,
I am not specifically familiar with the DEH-5800MP but many car stereos these days have an input jack on the faceplate (or under it) which is used to connect the stereo to a MP3 player using a special cable which is available from the manufacturer.
If your stereo doesn't have an input jack, there are other options. One popular method is to connect a wireless transmitter like this one to your MP3 player set to an empty FM radio frequency which you can receive using your car stereo
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 05, 2008 | Sony Network Walkman NW-HD3 MP3 Player
Open Questions:
See all Apple iBook G3 Mac Notebook Questions
Apple iBook G3 Mac Notebook Logo
37 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
