it is located at the back of the drum inside an oval housing. if the element coil is not broken, you may need the thermal cut off kit which is part #3977393, it contains 2 thermostats. the element part #is 3403585. hope this helps.
My Dryer had a 3 prong plug. I recently built a house which has a 4 prong plug. I changed out the...
(More)
My Dryer had a 3 prong plug. I recently built a house which has a 4 prong plug. I changed out the plug and connected the wires according to color. The center wire is white and at the top of that connection, there's a thin green lead running to the outside of the dryer that is attached to a screw and labeled, Outside ground wire. My problem is, I have a fourth wire that's green and have no place on the dryer to plug it in. What do I do?
