speedstream 6520 and PS3 NAT3 I can't get a nat 2 even after enabling dmz and redirecting appropriate ports. what gives? the ps3 is hard wired to the 6520, and I'm not using any of its wireless features as of now.
Comments:
Nov 08, 2009
- thanks. I'll try and let you know.Nov 09, 2009
- I verified that I have the latest firmware installed, though I admit dealing with my ISP is a challenge. However, I received an additional port to forward from the PS3 folk, 3658, and when i try to forward it I get the message that it's already locked by the system for another application. How do i determine which application is using it, and how do i free it? I'm trying this with two separate computers, both running XP, but with totally different programs loaded on them.Nov 09, 2009
- Ok. a couple of things. I used your check port routine and, lo, the ports are not open, despite setting them in the router. There's one additional problem also. PS3 states that port 3658 should also be open, but I get an error when I try to enable it that states it's in use by the system elsewhere. How do I find what app is using and locking this port? I've tried it with two computers, both running XP, but handling a totally different set of software apps.
I'll play with my ISP-provided firewall and see if i can sort through the port issue on the others. I'm not a terribly experienced user, so I appreciate any and all advice. Thanks for steering me this far.Nov 11, 2009
- hey, thanks. it shows that 3658 isn't being utilized, which is more in keeping with what I would have expected. I guess that means I need to look at my router more closely. ??? Unfortunately, my ISP isn't assisting in the least. Should i be looking at a different type of router for gaming? Living in the boonies, I only have access to DSL so I am rather limited.....Nov 11, 2009
- Thanks. I think that's where I'm at. My ISP is of NO help whatsoever. Since I'm so far out in the boonies, I'm stuck with DSL. Can you recommend a router/modem that will improve my gaming?? ( i realize the limitations, but would like to optimize whatever i can)Nov 11, 2009
- Thanks. I will try resetting and let you know. This may take me a day or so ......Nov 12, 2009
- since I was unable to do a hard reset on the router, the ISP is going to be supplying me with a new router today. I will try that out and let you know. If i have the same issue, I'll try a different brand and be done with it. Thanks for all of the help.Nov 12, 2009
- Yes. I have been supplied with enough info to get my ISP to replace the router. If I still have issues, I now know an appropriate router to select. Thanks so much for all the help.
