Subwoofer Module N-200 ( Nuance ) Short on circuit board
I have a Nuance subwoofer module N-200 with a short on the circuit board does any body know how to fix or replace the board.
  • 2 more comments
  • Anonymous Feb 24, 2008
    I have the same problem. Looking for a solution
  • the12thmann Nov 02, 2008
    I have the same problem, anyone had any luck in finding sa fix for this?
  • Cryoman Feb 14, 2009
    I have the same problem with both of my baby grands. If anyone out there has an answer, I would love to hear it.
  • dirty Dirk Apr 26, 2009
    cant keep power on my ciruit board no big sound
    subwoofer module n-300 (nuance).
I'm working on a guys board looks like it is the Q10 and Q1 transistors I'll let you know how it goes.
Posted on Nov 20, 2008
  • Cailou
    Cailou Feb 14, 2016
    I have the same sub... Looks like q1 and q 10 are colpritts...did you have any luck finding and changing these transistors?
I have for sure one working N-300 amplifier and maybe a second (Depends if I can repair it, I think I know the problem, just waiting for parts). I am willing to take offers. If interested email me at ak47_138@hotmail.com.
Posted on Dec 23, 2008
  • irongoddogg
    irongoddogg Oct 07, 2012
    my n 200 just went again so if you can help me out would be great call 780 700 6982
Subwoofer blows fuse
Short circuited component/s at its circuit board. Check and replace it. Check for shorted component/s at the amplifier stage circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 06, 2015 | Boston Acoustics Audio Players & Recorders
The fuse of Jamo Sub-200 gets blown off. is there anyone who might know the reason. thanks
try replace the blown fuse with ampere and check the sound if still ok.
some fuse got blown if the load current exceed. maybe high volume can cause the high current.
other cause by short circuit coming from the amplifier.
Aug 26, 2011 | Jamo SUB 200 Subwoofer
I also have an Athena ASP4100 sub woofer which blew the fuse on the circuit board and when I replaced the fuse, it just blew it again. As an electrician, my understanding would be the circuit board has a...
You should look at the circuit board for the power amplifier and check for any leaking or bulged electrolytic capacitors. If this speaker uses the circuit boards made by AMI (such as most JBL and Mission sub woofers around 1999-2001 vintage) they had a lot of problems with this as well as bad modules. Google for the module S53AMI and you will find lots of info if this is what you have in that Athena.
Feb 21, 2011 | Athena AS-P4000 Subwoofer
I blew the circuit board on my jbl pb12 subwoofer. how or where do i find a replacement and is it expensive or a cheap part to fix/replace?
Sorry to hear that. The JBL PB12 are notorious for their amplifier module giving out. This item is not repairable nor is there a replacement (The module is potted into an aluminum heat sink). Actually, I need to clarify, as the late models used discrete components. If this is the case, either Repair it yourself (Google search PB12 Repairs) or take it to the local repair shop. (Or to a technical college with an electronics program, they may work on it!)
The best method is looking for a plate amp to replace the PB12 Amplifier - try the bash 300W. Several people have done this conversion. Be warned, you will need to do woodworking if you want to mount the plate amp on the box!
Mar 01, 2010 | JBL PB12 Subwoofer
2003 Chevy s 10. The fuse marked cruise control module, body control module, heated seats (it doesn't have heated seats) keeps blowing. It can happen 1 minute down the road or 10 minutes. The odd thing is...
The fuse in question also powers the instrument panel cluster ,also goes to SP200 -splice pack 200 where it powers BCM , CCM,multifunction switch - turn sig. headlamp dimmer switch and the WSW .Also if you have utility vehicle without memory seats it powers the front seats lumbar switch . Do you know how to check circuit's for a short ? Locate SP200 Splice Pack SP200
(CKT 41, CKT 241, CKT 341, CKT 817) Strapped to the body harness, under carpet in the RH dash area about 30cm (12 in) from the right kick panel .Do you know what a splice pack look's like ?
gm splice pack-5vwjdo4vj5u5qn0cs4zh2oxv-4-5.gif Disconnect circuit's one at a time till the fuse doesn't blow , then you found the problem circuit or componet . Disconnecting the BCM will cause the vehicle not to start an run . Anti-theft system . You mite try having the BCM checked for DTC'S - diagnostic trouble codes
Oct 24, 2017 | Chevrolet S 10 Cars & Trucks
Replacement parts for Infinity TSS-1100 subwoofer.
Same issue here. 3 years without problems then the burning smell and finally it died. I've removed all of the screws from the back but haven't had success opening the unit. Anyone figure out a solution to fix the circuit board?
Jan 25, 2009 | Infinity TSS-1100 System
Need wiring diagram
i dont think u need a wiring diagram. you should check your wiper motor circuit board first. on my 94 s10 the wipers either worked when they wanted to and now they dont work at all. just either replace the circuit board yourself ($19.95 on ebay) or replace the whole wiper motor ($60 on ebay) and your wipers should work. just give this a shot as its a good place to start. i myself am going to replace the wiper circuit board as its cheap, and really easy to access and replace. all you need is a screw driver. good luck. and no, im not a GM Technician. just owned my truck since day 1 and always try to check vehicle forums for answers first.
Aug 01, 2008 | 1994 Chevrolet S-10
Miller & Kreisel Subwoofer 60Hz hum
This is a common problem.  The potentiometer is damaged and needs to be replaced.  Potentiometer is a fancy name for volume knob.  It's a $5.00 fix if you know what you're doing.
Dec 01, 2007 | Audio Players & Recorders
3,305 people viewed this question
 Grubhead
Grubhead
