1. Belt (see if it is loosen) if the motor wheel is turning and not the belt, tighten it a little bit just enough to turn the wheel
2. Capacitor and bearing/bushing (check this if you turn it on the machine and you heard it just humming but not turning), if this is the cause, bring it to a technician and have it replace
Was this helpful?
Yes
No
Popular Solutions for GE 5.8 Cu. Ft. 3-Cycle
GE 5.8 Cu. Ft. 3-Cycle Extra-Large Capacity Gas Dryer -...
The dryer all of sudden started screaching while turning. When we manually spinning it backwards the...
(More)
The dryer all of sudden started screaching while turning. When we manually spinning it backwards the noise stops, but running forward it sounds like it scraping on something. How do we get the back off to see if something is cought up in the indise?
I have a GE 2 cycle automatic heavy duty large capacity dryer that only clicks when you try to turn...
(More)
I have a GE 2 cycle automatic heavy duty large capacity dryer that only clicks when you try to turn on. Is it worth fixing?
sometimes my gas ge dryer heats and will eventually get hot after i hear the gas fire up but for 2...
(More)
SOMETIMES MY GAS GE DRYER HEATS AND WILL EVENTUALLY GET HOT AFTER I HEAR THE GAS FIRE UP BUT FOR 2 DAYS NO HEAT???
After taking apart my dryer to lubricate a squeak, the belt came off and I cannot figure out how to...
(More)
After taking apart my dryer to lubricate a squeak, the belt came off and I cannot figure out how to put it back - it is very loose when I position it according to diagrams accessed on the web. Thank you so much for whatever help you can provide!
