Olympus FE-210 Digital Camera
Problem for Olympus FE-210 Digital Camera
The camera turns on - but you cant take a picture
By nesmithpatri on Nov 07, 2009
the camera turns on - but you cant take a picture - then lens seems to stick when it is trying to extend away from the camera and back for taking pictures. You can hit the view button and everything else works
Olympus FE-210
Solution #1
posted on Nov 08, 2009
Somewhat Helpful)
BillB-SA
Rank: Wiz  Olympus Cameras & Camcorders  Expert
Rating: 85%, 375 votes
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Was this helpful?
Yes
No
Popular Solutions for Olympus FE-210 Digital Camera
Questions and Unsolved Problems for Olympus FE-210 Digital Camera
Do you recommend Olympus FE-210 Digital Camera?
Answer
Answer
when turning on, the screen stays white, this happens after I did take several pictures and tryied... (More)
Answer
battery problems - takes A4 batteries- ord ones don't seem to work; rechargeable only last 15 mins... (More)
Answer
Where can I get a replacement latch for the battery compartment?
Answer
olympus fe 210,screen goes gray after taking a shot and stays gray. screen comes back after letting... (More)
Answer
My digi cam got wet n now its not working...ne idea how to make it work again?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Olympus FE-210 Digital Camera:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
