Question about RCA HD52W59 HDTV Projection Television
Leaking liquid The bottom of my tv rca hdtv 52" is leaking a liquid from it, it also has effected the blue hue on the tv color. What could be the problem and what is the fix or is there one. Tv is 2 years old
  • RCA Master
  • 8,617 Answers
Sounds like your Blue CRT is leaking coolant.It will affect the hue for sure and it will also destroy your circuit boards as it is corrosive. Clean any coolant that has spilled onto your Chassis before it causes corrosion. You can buy coolant to replace this, however you will need new seals. This is a proceedure you may be able to handle if you are dilligent and pay attention to details. Replacement coolant can be purchased at the following Link
http://www.matelectronics.com/ or this link http://electronix.com/
The seal will probaly have to be orderd through RCA, I am not sure if the links mentioned carry the seals or not you might give them a call to inquire. If I can be of any addittional help let me know.
Posted on Jan 05, 2008
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
On my Philis 51PW9303/17F projection TV, the colors are weak. Adjusting the color and tint have no effect on the color intensity or hue. I was given this set and it was worked on. THANKS Mike
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 30, 2008 | Philips 51PW9303 51" Rear Projection...
Blue Shadow
YOU CAN TRY TO ADJUST THE COVERSION POINTS USING THE MENU OPTIONS IF THIS DOES NOT WORK THEN YOUR CONVERSION CHIPS HAVE TO BE REPLACED IT COST AROUND 200 TO 250 DOLLARD
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Water looking droplets on inside of blue lens
droplits are more than likey air. sound like a glycol leak on the blue tube. look for liquid underneghth the tube. THis would require replacement of blue tube.
Dec 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Uneven Color on JVC Projection TV
hello i have a jvc 52" made in july 2004 replaced bulb twice under warranty plus replaced ballast board in 2005 replaced bulb dec 2008 my tv was before and after install having a blue hue reversed words
Sep 01, 2008 | JVC HD-52Z575 52" Rear Projection...
THE RED, BLUE, AND YELLOW COLORS SEPERATED ON A 52 IN HDTV. THE PICTURE SEEMS TO HAVE A GHOSTING EFFECT TO IT
Have you used the color convergence settings on your TV?When the settings are off you will get this effect sometimes if the TV was jarred pretty hard it goes out of alignment.There should be a setting on your menu.If that doesn't help it may need re aligned by a repairman.
Aug 10, 2008 | RCA Televison & Video
Blue Hue and lines on HDTV
what more can you describe as to the fault of the unit.is the blue hue there on all inputs and tuner mode and the lines are they also blue in color .
Apr 06, 2008 | Hitachi 51F510 51" Rear Projection...
Hourglass effect and fuzzy
You have a convergence problem and I suggest to get a qualified honest tv repairman because this is a highly technical problem in this model. Hope this helps
Dec 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
130 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
