Question about Car Audio & Video
Pioneer GMH100 Amplifier
I'm missing the Control Voltage plug, it's a 3 pin plug that delivers remote power to the amplifier can you direct me to where I can buy or get one?
  • 1 more comment
  • Margarito Jan 14, 2008
    Thank You Very Much
  • Anonymous Apr 22, 2008
    which pins do you use on the gmh100 pioneer amp? . . . ? number33w3@excite.com
  • philalperez Jan 01, 2009
    witch two pins do i use?
  • 631 Answers
If you don't need the OEM plug, you can use the type of connector used to connect to the terminals of a speaker. You will have to tighten the terminal slightly but one terminal will span the remote and acc pins and will allow you to use the amp. You don't need to apply power to the 'ill' pin of the plug. Be careful with the pins for the plug. The amps are known to having weak connections that break easily if excessive pressure is applied to the pins.
Posted on Jan 08, 2008
Try pacparts.com
Posted on Jun 07, 2008
  • memphispimp Jun 07, 2008
    try pacparts.com
I have a pioneer GM-X524 amp connected to a TS-W253C subwoofer and it isn't working. It has 12v power to it and a solid ground, but the power light wont come on and the sub isnt working
there should be 3 power related cables connected to the amplifier:
1-From battery to amp via fuse (positive)
2-From chassis of car to amplifier (negative)
3-From head units (power continuous) (blue or blue/white cable) to the amplifiers remote connection.
this connection enables the amplifier to switch on when the head unit is switched on and off when the headunit is switched off.
I hope this helps and let me know if I can further assist you.
....andy....
Jan 06, 2014 | Pioneer Car Audio & Video
Pioneer vsx 515 overload and shuts down what can i do to fix this problem.
hi,
First of all remove all the speaker connections from the amplifier. After that power the amplifier and check the overload (protect) show or not . if not, then any of the speaker is damaged or you have to check the impedence of your receiver and speakers. It will be written on the rear side of both receiver and speakers in ohms. PIONEER recommend to connect 8 ohms speakers in to this AV receiver. If you are using 6 ohms speakers you have to do some setting in the AV receiver.For that do the following
1. With the receiver in standby, press STANDBY/ON while holding down the SPEAKER IMPEDANCE button.( Each time you do this, you switch between the impedance settings: )
SP 6 OHM - Use this setting if your speakers are rated at 6 Ohms
SP 8 OHM - Use this setting if your speakers are rated at 8 Ohms or more
You are not able to connect speakers with impedence bellow 6 Ohms with this receiver. Becuse the AV receivers impedence range is 6 - 16 Ohms.
If then also it shows protect you have to check the amplifiers hardware.
AV receivers shows protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong.
Normally AV receivers show this when any of the output amplifier get some problem. there are six amplifiers in this AV receiver. May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
You have to check the amplifier.
for that you need digital multimeter,soledring iron screwdrivers etc
open the amplifier , then power it on. connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). then connect the positive terminal to all the output transistors emitter pin one by one . the voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
after replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. put the bulb in a holder. now you have to wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim . if so check the display, is there is protect mode is on or not . if not and come back to normal operation ,then remove the power , remove the bulb insert fuse and check
connect the power and check.
If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components.
ok
Jul 27, 2011 | Pioneer VSX-515 Receiver
My Pioneer Elite VSX-53TX volume quit in the middle of a video. the read out on the unit says - - muting - - and no, we did not push the mute button. do you have any idea how to get the volume back
hi,
First of all remove all the speaker connections from the amplifier. After that power the amplifier and check the protect show or not . if not, then any of the speaker is damaged. If then also it shows protect you have to check the amplifiers hardware.
ok
Mar 23, 2011 | Pioneer VSX-53TX Receiver
My sub woofer wont work? the stereo turn on then it shuts back off.
hi,
ok
Mar 08, 2011 | Pioneer SX-315
No power to my amplifier
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL DOES NOT POWER UP, THEN CHECK THE VOLTAGES AT THE POWER TERMINAL TO GROUND AND MAKE SURE THAT THERE IS 12 VOLTS PRESENT. ALSO, CHECK THE REMOTE LEAD VOLTAGE AND MAKE SURE IT IS NOT BELOW 11 VOLTS, WHICH COULD BE CAUSED BY A DAMAGED REMOTE OUTPUT FROM THE RADIO ITSELF. IF YOU ARE UNABLE TO CHECK THE REMOTE LEAD, THEN DISCONNECT IT FROM THE AMPLIFIER AND TEMPORARILY INSTALL A JUMPER FROM THE POSITIVE POWER TERMINAL AND THE REMOTE INPUT TERMINAL ON THE AMPLIFIER, WHICH SHOULD FORCE THE AMPLIFIER TO TURN ON. ALWAYS MAKE SURE TO VERIFY THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%. IF THE AMPLIFIER STILL FAILS TO TURN ON, THEN THE IT WILL NEED TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 19, 2009 | Pioneer GM-3100T 300W 2-Channel Amplifier...
I dont have a wiring diagram for the 16 pin plug on a deh-p2500 pioneer car stereo. Can Anyone help? It is a used unit.
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 25, 2009 | Pioneer DEH-P2500 CD Player
What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
Amplifier wiring diagram, pioneer gm-x944
These amplifiers are universal. You have the speaker positive negatives, power "Red", Ground "black", and remote off/on "blue". Thanks
Jun 05, 2009 | Car Audio & Video
There is no sound coming from my 15's when my stereo is on
it is Either the RCA Jacks or the Blue Remote Lead Wire is Bad or Loose in the Harness inside the Dash. Please Rate My Response! Thanks!
Feb 03, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Car Audio & Video Logo
899 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
