Question about Harman Kardon Harmon Kardon SoundStick II Speaker System Computer Speakers
Soundsticks 2 my subwoofer seems to be literally pulsing. there is even a pulsing noise from my sound sticks. i got it yesterday and everything was working fine but about and hour or two later, it stopped working and began pulsing. does anybody know what's wrong?
  • uhoh123 Jan 09, 2008
    yeah, the same thing happens on every computer
    Genius:
  • 1,067 Answers
Hows the control vol in windows all way up meada player settings is it pluged in all way turn down master then back up reboot comp
Posted on Jan 09, 2008
  • nick helpap
    nick helpap Jan 09, 2008
    do these speaker do same thing on anther comp ?
  • nick helpap
    proably bad set then in cicuit bord be hard for u to do does just top speakers work ok as speakers with out bass
My MacBook's audio still on even when harman Kardon speakers are connected to the computer.(Original version with USC connectors).
As I seem to recall the very first version was powered by the computer and as such may not be compatible with your Mac. I may be thinking of Apple's Clear speakers though? Do your HK Soundsticks have a power adapter or AC cord?
Oct 15, 2013 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
Sometimes the volume on the soundsticks is incredibly low even when i crank everything and restart everything. Why?
Have you tried the volume control on the right hand stick? They go into a mute mode if they are not used and you need to hit the volume button to un-mute them.
Feb 14, 2010 | Harman Kardon SoundSticks II Computer...
Soundsticks have developed a loud intermittent annoying crackle
YOUR ONLY OPTION IS TO TAKE IT APART AND CHECK SPEAKER MEMBRANE I SUSPECT THIS HAS PARTIALY BECOME UNATACHED FROM THE SPEAKER IF THAT IS THE CASE IT WILL NEED TO BE REPLACED
Dec 28, 2008 | Harman Kardon SoundSticks Computer...
Only a steady pulse comes out of my bull power
hello, it seems that you may have a bad ground on your amp? turn everything off(pull amp fuse at battery) and go to the amp ground and clean paint away to bare metal! secure ground tight and make sure the car battery is not low voltage! this may stop the pulse! the sound problem of no sound in speakers, if still there! make sure the speakers are not shorts or pinched to ground! this could damage the amp! hope this helps, good luck!
Jun 12, 2017 | Magnat Bull Power Reflex 300 Car Subwoofer
No sound from subwoofer
You're in warranty. Appers to be a common problem. Soundstixks should either tell you how to fix it or replace your system.
Mar 03, 2008 | Harman Kardon SoundSticks II Computer...
No sound from Soundsticks
Pannik
First things first:
1) time to change your stick speakers.
2) if got warranty, use it, if not, have to RMS them but I just
counsel you to change for others.
Open Sky
Jan 31, 2008 | Harman Kardon SoundSticks Computer...
Harmon Kardon Sound Sticks
Hello there
First things First:
1) check cables, and the input cable to your PC.
2) Check for right voltage, may be somethings is chargind a lot**
3) Power regulator on the Speakers is damage.
4) RMS your Spks, for replace. or warranty.
5) try in another computer. ( if apply)
Jan 23, 2008 | Harman Kardon SoundSticks II Computer...
Harman Kardon Soundsticks II left speaker
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
Jan 21, 2008 | Harman Kardon SoundSticks II Computer...
Subwoofer just stopped working. There's power but no sound.
I have the same problem. My guess is that the subwoofer coil is messed up. You MIGHT have to get it recoiled. But before you do any of that get someone with a sub to play their sub in your car, if it works.... then your sub is messed up, if not.....then your amp is messed up ( trial and error ). Today i noticed my subs rubber surrounding is crooked, that may be the problem for me. Also when I press down on the sub it makes a sticking sound, like something came loose. So once i get everything opened and out ill let you all know the solution. Good Luck!
Jan 05, 2008 | Jensen JS1000-A Subwoofer
No Sound on Harman kardon soundsticks 2
Ok Dave Go to your Start Menu Next Control Menu,Find audio and devices,Click on it,Go to Hardware Tab Click on it,Then at the botton is Properties Click on it.Find the Drivers tab,And then go down to Uninstall,Reboot and let windows reinstall driver,Make sure you are plugged in the Right port and Power for spkrs is Plugged in...
Jul 19, 2007 | Harman Kardon SoundSticks II Computer...
Harman Kardon Harmon Kardon SoundStick II Speaker System Computer Speakers Logo
320 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
