I have a Hamworthy/Bristol 3S10-50 scuba air compressor. It gets to 100bar and then the 3rd stage over pressure valve leaks. The over pressure valve is set to 1000psi.I have cleaned the 3rd stage suction/delivery valve as well as the 2nd stage suction and delivery valves with no joy.
well,fit a pressure gauge in the 3rd stage so that you can read at which pressure the over pressure valve is working,at the same times you will confirm if the over pressure valve is not faulty
Blows fuse when tring maintain pressure ? Its a craftsmen pro series 150 psi 25gal on 20amp outlet...
(More)
Blows fuse when tring maintain pressure ? Its a craftsmen pro series 150 psi 25gal on 20amp outlet with 10g wire to its own 20amp circuit breaker?
Compressor keeps cutting out it is an Iwata silent Aire it only cuts out when the hose and gun are...
(More)
Compressor keeps cutting out it is an Iwata silent Aire it only cuts out when the hose and gun are attached.
Certain nails cause my Akuzuki floor nailer to jam. Others (same type, brand, and size) work just...
(More)
Certain nails cause my Akuzuki floor nailer to jam. Others (same type, brand, and size) work just fine. How can I know which is a good box to purchase and which will jam?
