CD Players
Problem for CD Players
Generic problem for all CD Players
Hi, i have a 1984 fisher studio standard cd
By kdecarlo666 on Nov 07, 2009
hi, i have a 1984 fisher studio standard cd player. when it plays, it sounds excellent and works fine. the machine will play cdr's as well as normal cds. however, some cds it simply will not spin. it clicks three times slowly, and then does nothing. i figured out a trick that works 100% of the time: tilting the entire machine at a 45 degree angle will get the disk to spin, i can then return the machine to its normal, level position and it plays fine.
there seems to be no rhyme or reason to the disks it will and won't play. in fact, when i was comparing the sound quality of this cd player to a newer dvd/cd player (no difference in sound quality by the way) i was using two identical cds, and yet the fisher would only play one of them. interestingly as well, once the fisher starts playing, it deals with bad cds quite well and does not skip. it's just an issue of getting it started. i opened the machine in the hope of finding one 'pot' that i could turn up, but instead found 6 adjustable metal squares. i fiddled with them, but it made no difference, and i returned them to the original position. i also cleaned the laser while i was in there, which made no difference.
please help!
Best Solution
posted on Nov 09, 2009
Very Helpful)
Abrsvcs
Rank: Guru  Home Audio  Expert
Rating: 88%, 1820 votes
There are a number of causes of this problem. Can you post the model number please? I suspect that the spindle motor is tired and can not get the CD up to speed fast enough. There were a number of very common failures for FIsher units, but they varied based upon the model. If you can update this with the model, I can get you more details.
Thanks,
Dan
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
dunnbiker
Rating: 87%, 126 votes
Thanks for the informative write-up. So few know how to describe a problem (example: it's broke) or have the intuition to check a few things out.
A surviving 1984 CD player? Good for you. And they originally said the lasers would burn out in a few years.
Don't read too much into sound quality and tracking of defects for this problem. It sounds like a load status sensing problem. Does it make the thee clicks when you load no disk or one upside down (to simulate a bad disk)?
You're probably on the right track with the tilt. I suspect you need to locate the sensor that 'sees' the presence of the disk in the first place. Can you try your troubleshooting with the covers off and observe what may be different at the tilted angle?
Was this helpful?
Yes
No
Popular Solutions for CD Players
Questions and Unsolved Problems for CD Players
Answer
teac mc-cx 40 dab mini hi-fi I wish to buy this unit,on Appearance,appears good value,but not sure... (More)
Answer
same problem cd player acts like it wants to play but cd doesn't spin.
Answer
cd disc wont eject,it stucked in the try,help me ,while i pressed the eject button,it comes out only... (More)
Answer
red lettering "HOLD Disc" will not play when the play arrow is pushed? Sony 100 cd player
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For CD Players:
Top CD Player Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more CD Player Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
